I know this sounds stupid but how do launch my car?
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I have a 91 RS 5spd and Ive never taken it out to the track and have no idea how to launch off the line I tried twice, once I stalled and made and *** of my self and the second time I just burnt out big time Any help would be nice befor I go to the track and make an *** out of my self a second time.
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
do you have an open or posi rearend? what kind of tires are you on? a good launch for my car with 3.73 posi and 255/60/15 tires is about 2500 rpms. don't just sidestep the clutch, keep your foot on the pedal and engage it quickly.
Car: 84 Z28
3.73 open? did you buy that? you don't come across many open 3.73s. i'd say experiment with about 2000 rpms to start and work from there, every car is different and so are the drivers so experimentation is necessary. remember, t5s and stock 10 bolts are weak and the less shock loading you apply, the longer the driveline will live.
No I did not buy it it came with the car when i bought it. the build sheet says 373 but when i stomp on the gas i leave one track. Could the posi be broken? Did posi come with drum brakes b/c that is what I have?
Car: 84 Z28
i don't think they ever built non posi 3.73s. you may want to search previous posts to find out for sure. the posi in 7.5 inch 10 bolts is a gov lock system and they do break easily so i guess that could be the reason.
Car: 1984 Pontiac Firebird
Engine: 2.8l :(
Transmission: T-5 Five Speed
I put my toe on tha clutch, heel on the brake and get the RPM's to whatever works for you, mine is around 2000 i think
Car: 84 Z28
that's on aodd way to launch badbird. why do you need the brake? unless you were not on level ground, there is no need to have your foot on the brake.
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my 84 TA HOe is a one legged wonder
i heard that most of them are that have 3.73's
There were non-Posi 3.73's in F-bodies from 1983 - 1986.
Axle Codes
1983
- 4JK
- 5JK
- 5KM
1984
- 6JK
- 6PM
1985
- 8JD
- 8KB
1986
- 2HC
- 2HM
These are all 3.73 STD Rearends.
Axle Codes
1983
- 4JK
- 5JK
- 5KM
1984
- 6JK
- 6PM
1985
- 8JD
- 8KB
1986
- 2HC
- 2HM
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I will contribute to the drifting topic... next time your rear tires are in the air, turn one tire, if the other turns in the same direction you have posi... if they turn in opposite directions it is either one tire fire or a broken posi.
