Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Weigh Reduction
Old Jan 3, 2003 | 03:42 PM
AFast83z28's Avatar
Weigh Reduction
What all can you safely remove out of the engine comparment or the body on a 1990 v6 RS? I removed teh windshield wiper washer fluid tank and lines but is there a motor or anything? I don't want to take out the windshield wiper motor though Just curious as to waht else I can remove. I am not taking out any interior and not removing the A/C. Just trying to get the weight lower! Also I have read a few tech articles but never this direct question!
Old Jan 4, 2003 | 12:03 AM
89WS-6's Avatar
I dont know if you want to take out your smog or not, but mine came out with hoses, fitting, pumps, brackets, probably another V8 in there somewhere just to drive the thing. Anyways, that helps, plus it cleans up your engine compartment reaaaaal nice.
Old Jan 5, 2003 | 02:27 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
for me: smog pump and lines = 14lbs
spare tire and jack= about 38 lbs
windshield washer fluid= 1-4 lbs
manifolds to headers = probably saved about 5-8 pounds
thats about all I could remove and keep the car nice, however the 86 will be a total gut job, hope this helps
Vic
Old Jan 7, 2003 | 09:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What kind of weight does my fibreglass hood save over a typical steel hood?
Old Jan 9, 2003 | 06:38 PM
CAMARO85500's Avatar
Your motor for the windshield wiper tank is on the backside of the tank itself.You can take out all the heater core stuff also.I took off the wiper tank the heater core and some stuff under the hood latch area also.The hood latch also.Also the wipers and the motor for the wiper also.
On the fiberglass hood with probaly lighten it up 50 pound or so.I have a lift off hood on my car.
I have a bbc in my car and that made it heavier in itself.
http://camaro85.homestead.com/page1.html
Old Jan 9, 2003 | 06:39 PM
vicv8rs81 if you want some headers for bbc i will give you a deal on mine.
Old Jan 9, 2003 | 08:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A BBC only adds 100-150 pounds more than a SBC. Using aluminum heads makes it roughly the same weight as an iron head SBC.
Old Jan 16, 2003 | 09:48 AM
Frank Mars's Avatar
Weight saved is speed earned
The fiberglass hoods save a lot of weight.
I am not sure how much since when I got my car it had one but when I lifted the hood on my friends z28 it weight a ton compared to my daytona fiberglass hood.
As was also said, Smog pump adds weight, but not much.
you could remove the inner wheel skirts I think. I have not done it and dont know what they weigh.
I removed the AC from mine but I may put it back due to the fact that I drive the car on the street more than the track....
Frozer!!!
Jan 19, 2024 04:55 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
gord327
Oct 3, 2015 01:25 PM
