does anyone here run 11s on motor with less than 360 Cubic Inches?
i have a bet going with a buddy of mine that my car can run 11's. he says that NO n/a 350 with 4.11s or less can run 11s in a full weight car, being 3200 ish lbs. he just doesnt believe. show me what you got. lets prove him wrong here guys, he drives a BUICK.
adam
adam
Car: 84 Z28
Engine: 305 L69
Transmission: 5 spd
i dont know where u live but my cousin has a done up 340 in his 74' duster and he hasnt seen what he can run but he got up to 95 miles per hour in a block and a half!!!!!!!!:hail:
i know its possible, im just trying to find someone who has done it, to win a bet. i cant find anyone to speak of who has a
pump gas
full weight
less that 360 ci
4.11 or taller geared car that runs 11s n/a
like i said, i know its possible, but im looking for websites and verified cars that do it.
adam
pump gas
full weight
less that 360 ci
adam
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Power to weight has nothing to do with CID.
Estimating an average race weight of 3500 pounds for a street car, you need to be putting at least 400 HP to the rear wheels to run 11.99. 3200 pounds needs over 360 HP. The lighter the car, the less HP is required. Trying to achive that much HP with small engines is possible but not easy with pump gas.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I can think of two people that fit your criteria.
Look for Mike Davis on this site...
http://www.mycar.net/mafb/registry/detail.cfm?id=201
On the Corvette forum, look for a guy named 'Ralph'...he's also in the high 11s with a stock shortblock.
Now go take your buddies money.
Car: 86' Z28
Engine: 355
my goal for this season is to take my NA 355 to an 11.99 or better, with a 4.10 gear, t-56 and bfg DR's. The local strip opens up feb 21st. so i'll let you know how it goes...
Eric
Eric
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
Its very possible to run those numbers. here is an example.
Car: '71 camaro, fuel injected 360ci small block, 350-500hp shot of nitrous, custom BRT 2000 hybrid manual three speed clutchless trans with air brake, converter, ladder bar suspension, GM 8.5-inch 10 bolt rearend.
Best E.T. and MPH: 8.35 at 162 MPH
Yeah, I'd say it is possible...
Transmission: 4L80E/4L80E
That's hardly "NA".
I'd say it's possible; what I wouldn't include in the possibilities is driving it to work every day.
Don't forget that 11.99->quicker requires a cage.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
um I think I found some info.... heck most of these cars are even STOCK or very close to
http://z06vette.com/forums/showthrea...threadid=25689
so yeah can it be done.... again yeah
Has your friend ever heard of a LS1?
346 ci
There are literaly hundreds of people running 11's N/A with a 3300lb+ raceweight and 3.23 gears.
All it takes is a few grand for some ported heads and a cam and traction.
-Doug
346 ci
-Doug
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
There was a 91 Z28 in an old issue of GMHTP that ran 11.40 @ 116 with a superram, trick flow heads, CC306 cam, 3500 stall and 3.73 or 4.10 gears with a 355.
Your friend is smoking something.:lala:
NHRA
have u checked out the super stock group in nhra.theres a guy with an old 60`s mustang with a 302(or 289).running in the tens.no poweradder stock heads,stock compression,there is no rule for the cam,stock intake stock carb.
dave
dave
Car: 91 Z28
Engine: LB9
Transmission: WC T5
My buddies ta runs 11.80s with a na 355, his car is awesome, its making 580hp, with a super t10 4spd and he drives it a lot of places, I have never seen his temp go over 180...I can try to get some pics if any1 wants to see it
...this is in 1982...
1960 Corvette, complete and street legal. street driven,3360 # with driver, 283 chevy, 30-30 Duntov cam (read semi mild),
1 4 bbl., chevy iron heads, pump gas..
...avg. when completely sorted 116+ mph / 12.30's thru street exhaust 2 X 2 1/2 " mufflers and on street tires, that's E60 belted,
no "soft" compound. Best 117.20 / 12.19
Car run at Fremont, CA. Attribute this to tireless hours of dye grinding, testing, failing , more work, success, lots more work, more improvement, ...over a 2 year period.
PS For doubters , I still have the car intact.
PPS A fellow ran a 3rd gen (looking) Camaro race car (glass etc. ) 283 motor, 151 MPH!! He was shifting @ 11.500 so pumping some air.
Car: 1993 Ford Mustang
Engine: 5.0L
Evidently my first post regarding how my car ought to be in the 11's as soon as a few issues are straightened out was deleted, but I'll add this...
the NMRA F/S guys are running 11's with a max. 310 cubic inches, and stock cams at 3200+ lbs.
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Trax is very close....................
Traxion is very close to 11s N/A with a 355 motor.
See:
http://www.mycar.net/mafb/registry/detail.cfm?id=101
See:
Car: Damn
Engine: This
Transmission: New Stuff
Another person who is aggrivatingly close is David91RS/Z28. He is running an efi 355 to 12.0s and pulls over 114! On a stock T5 to boot, so there is alot of improvemt in the launch that is left on the table due to "not abusing" the T5.
Sure he hasn't gotten an 11 yet, but you do the math. Sure its possible.
Check it out here http://www.i-55.com/~davidlt
