Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What will it run?
Old Mar 22, 2004 | 04:23 AM
Trns83's Avatar
Car: '83 Trans Am
Transmission: TH350 w/2500 stall
What will it run?
Just ordered a new motor for my 83TA, and of course, before i've even turned the key or run it in, want to know what it would do down the quarter mile. Its set up as follows:
-350ci Vortec (~330hp without the three mods below)
-hyperautectic flat top pistons giving 10:1 compression
-Speed Pro Cam .480 int/exh, duration @0.050 230 int/exh rpm range 2200-5500
-Power Plus Performance Intake Manifold
-Q-Jet (rebuilt, standard jets)
-Hedman Hedders with 2.5" single exhaust system, lukey straight thru muffler
-TH350 with 2500 stall
-Standard GM ignition
-Standard single snorkel & cowl air cleaner
-stock 3.7 rear (originally a T5 car, damn thing broke!)
-standard 15-inch turbo-fin wheels with 225's all round
That's about as much details as I can think of...
Old Mar 22, 2004 | 04:35 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
id say your gunna need some traction mods. maybe a slp posi rear, some sticky's, and a few other mods.
sounds like a nice setup though..
Old Mar 22, 2004 | 11:54 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Your most likely looking at low 13's in good tune if you can get traction. I would invest in some subframes and LCA's at least. Good Luck.
Old Mar 23, 2004 | 03:44 AM
crawlin 25th's Avatar
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
i dont see low 13s... maybe hi 13s just a guess though....
Old Mar 23, 2004 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I see tire smoke in your future...
Low 14's.
Old Mar 23, 2004 | 03:30 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Almost identical to the setup I am running. Times in the sig on radial tires. I will have better numbers this year with a better tune and slicks instead of balding radial T/A tires.
Old Mar 23, 2004 | 05:30 PM
Trns83's Avatar
Car: '83 Trans Am
I made a mistake in on the cam spec, apparently it is actually rated from 2200 to 6500rpm, although you can't expect much power past about 6000.
Souds like traction will be a problem. After the motor has run in, I will further mod the exhaust, and wheels to get some more rubber at the back. Then a dyno tune and possibly re-jet the q-jet...
Will also look as the sub frames, at least a stabiliser across the engine bay...
Old Mar 24, 2004 | 08:35 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
why do you guys think he will be in the high 13's or low 14's with that much motor? i am guessing you guys are basing that on the tires and suspension if that is the case then i would agree but with the right traction i would say mid to low 13's
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
