Track Today... does this sound right?
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Well I made it up to the track today, and I got 4 runs in. It was the first 4 runs of my lifetime at a track, and naturally I need to work on R/Ts. Here's my runs:
15.979@84.90 2.342 60 ft
16.003@85.02 2.407 60 ft
15.923@84.59 2.298 60 ft
15.941@85.29 2.342 60 ft
I personally don't think there bad for a 305 TPI engine with 175k on it. Do they look about right to you guys? I think my 3.08 gears are hurting me pretty bad, with 3.23's will I do much better?
Any input is appreciated.
It was cool at the track today, with a strong head-wind, I think the wind hurt me a little too.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i was gonna say.. my stock TBI 305 beat your times, then i saw your running AT.
ya sounds about right im sure their a lil room for improvement, when i first ran i was high 15's low 16's and now if my car would ever run good, i can make 15.7 constant, 15.6 best time ever
Car: 1988 GTA
Engine: 5.7L/L98
Hey Mystic those are fairly consistent times. Were you going off the second light on the last run? Little more practice at consistency and you should be ready for the brackets trophy.
Let me know when your going again I will take the time off and get the GTA up there.
Have you ever ran your car? I'd like to see you get out there and run it.
Car: 1988 GTA
Engine: 5.7L/L98
Nope not yet. I have some mods sitting in the house also. Headers, Runners, port work to be done. I want to get an initial time though and see the improvements. So I will take her out probably in two weeks. She better be in the high 14's at least right now. If not I know I am out of tune somewhere. Were you standing on the brake at all or just idling and stomping on the gas.
Take off I just stomped on the gas when I went... 2nd light.
Burn outs I had to do a brake stand basically.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Slow 60' times but nice consistancy. Dial in 15.92 after that and hope the car doesn't find additional traction.
Even on test and tune days you should practice dialing in. After a couple of passes and you don't change anything, guess what the next pass will be then see just how accurate you can be.
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
what kind of elevation are you at? your consistancy is awesome, but that car is capable of low 15's stock.
if you get the launch down better that time will really drop at the big end.
.1 seconds on the 60' will almost give you .2 at the end...
put 4.10 gears in, and a posi... 14's for sure!
I think I need a new MAF, plus my engine is at 175k, valve seals starting to leak a bit... I'm sure my rings aren't the tightest either... I don't think the time is half bad for it, I do know I need more gear though.
I'm planning on the 3.23 rear end because I already have it... Then headers are coming pretty soon. We'll see how things go then, I have a 350 in the garage, so that will probably be in, sometime in the summer hopefully.
Car: 1988 GTA
Engine: 5.7L/L98
morrow
Jan 13, 2024 12:29 PM
