Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
first time at track
Old Mar 28, 2004 | 12:50 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
first time at track, 129.77mph
went to friebird raceway in boise idaho yesterday , eleavation 2700' after waiting out the rain they opened up the first 1/8 mile first run
r/t .377
60 1.847
330 5.414
1/8 8.295
mph 86.71
next run the opened up the full 1/4 and i turned on the bottle
r/t .215
60 2.893
330 8.416
1/8 11.556
1/4 16.305
mph 105.31
the bottle never came on and it fell on its face off ther line (no vent extensions) cked the switch and linkage , the secondary acc.pump arm was hitting the inlet fitting . i was onlt getting about 3/4 throttle !!! changed arms and tried again this time i blew the et streets off out of the hole but still ran
r/t .363
60 2.13
330 5.353
1/8 7.845
mph 99.73
1000 9.941
1/4 11.686
mph 129.77
that was sidewase in 2nd and 3rd and still leaving black marks in 4th and they had vht'ed the whole 1/4 before the secomd run
tried a 4th run but it died off the line again the only good thing on the 4th run was the .001 r/t
this is with a 700 carb and my smallest fogger jets , and 8* of retard because its a new motor (safe tune)
what should i have run if i had not spun off the line with that mph ? i had a 1.8 60 foot prior and that one was 2.1. how much is the 1/4 time drop to the 60 foot time ? i have herd .2 in the 1/4 for each .1 in the 60 foot.
mike
Old Mar 29, 2004 | 06:55 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
here is a pic of the time slip
Old Mar 29, 2004 | 06:57 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
try again
Old Mar 29, 2004 | 07:19 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
If you can hook really hard, you should be in the lower 10s. Just look at the difference traction made for the car in the right lane.
Old Mar 29, 2004 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The car on the right has traction from looking at the 60' time and ET but the 1/4 mile MPH is very slow. Was that an elimination round and your opponent hit the brakes at the end? If not then his car is geared to max out at the 1/4 mile but should have a bit faster mph.
You MPH is huge compared to your ET. I don't know if 10's are possible but low 11's should be there if you can get the traction issue solved.
Old Mar 29, 2004 | 10:18 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
it was just opening test and tune. i think i am going to have to
go to a bigger tire . that was with 26x10.5x15 et streets. only 8.2" of tread . thinking 28x11.5 or 12.5 but not sure if they will fit
Old Mar 31, 2004 | 10:24 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
That's not slow, that's called a huge stall and big sticky tires most likely. Obviously this person knows how to maximize his whole setup and get about every hp to the ground. Remember 1 tenth you knock off your 60 ft is 1.5 tenths off your 1/4. Of course this is an est., but from my exp. it's pretty accurate. Look at it this way, my car ran 12.20's at 117mph with 2.1 60 ft. times. That was with drag radials. If I would have ran full slicks and upgraded suspension parts, I could've ran 11.30's at the same mph, since it doesn't change much, and that's of course with around a 1.50 60ft time. See? MPH doesn't change ET, that much, traction and hooking up do.
Old Mar 31, 2004 | 01:33 PM
TexasLT1's Avatar
Car: '92 RS
I'm pretty sure Stephen knows what he's talking about.
automec, how much are you spraying?
Old Mar 31, 2004 | 03:46 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
AUTOMEC, I saw you the other day driving the Camaro. I was in my '87 IROC getting ready to turn off of Skyline onto Grandview. You passed me headed towards the airport.
That car sounded MEAN Its so damn cool that another 3rdGenner is in Idaho Falls!
BTW: Nice run! Especially at this elevation? Have you ever raced (damn I can't remember his name).... Andy? He has the red/yellow '86 IROC in town?
BTW: I never see your car at Downtown Performance anymore... Are you friends with the owner or do you own it?
Old Mar 31, 2004 | 09:08 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
hey dante , thanks for the compliment. its kevin that owns the red/yellow 86 and you can find us around each other most weekends. his best run last year was a 10.07 @138.6 . we played around a couple of years ago and it was dead even . his brother jeff owns the purple 85 with the pro charger .
the car has not been anywhere but my shop sience last augest when i broke 7 pistons and cracked 6 cyld. walls. just got the motor running 2 weeks ago ,it had 100 miles on it when i ran it .
i am good friends with the manager of downtown, and buy lots of parts from them being that my shop is a AC Delco TSS shop
mike
Old Mar 31, 2004 | 10:09 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
i was using my smallest jets 28's and that a 250 shot i was trying to be easy on the new motor only 100 miles on it . also pulled out 8* of timming
mike
Old Mar 31, 2004 | 10:32 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I disagree, my friend's S10 runs those numbers at the same mph, just a really good bite off the line.
Old Apr 2, 2004 | 10:41 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
mike
Kevin and Jeff, thats them! I bought their exhaust system off of them at the car show/swap meet at Tautphaus last year. Unfortunately until I get some big money together, I'm stuck with my 305 TPI for now
BTW If you or anyone else in the area needs a set of 85-90 IROC/Z28 gfx, let me know. I recently went with 91-92 GFX and have my old ones for sale.
Anyhoo - Good to hear from ya again.
Old Apr 2, 2004 | 06:43 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Nice times with some traction your car should fly (or atleast attempt to ). Do ya mind throwing down some motor specs?
Old Apr 3, 2004 | 12:28 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
400 ci block 40 over bore destroked to 380 ci
bored w/tork plates, lined bored, deck plugs , decked, short fill
Splayed 4 bolt mains caps and straps on 1&5
ARP studs on mains, heads, pan, covers
Windage tray
SRP forged flat top pistons 11 to 1 compression
JE nitrous rings
Moroso deep sump pan and high volume pump
3.48 stroke GM steel crank, polished, cross drilled, and indexed
5.7" Childs & Albert steel H-beam rods
Competition balanced
Cloyes true roller chain
Comp Cams solid lifter 252,260@.050 dur. .541.559 lift 4/7 swap
Comp Cams push rods
Comp Cams triple springs with 10* locks
Comp Cams pro magnum roller rockers
Stud girdles
Dart pro 1 “230cc” aluminum heads
2.08" intakes, 1.60" exhaust
Ported and polished, flowed to 308 intakes, 207 exhaust @ 28"
Weiland team g intake. ported, and port matched
Holley 700 carburetor
NOS Pro race fogger adjustable 150 to 600+ horse
NOS duel purge solenoids
NOS window switch
3 gl. Fuel cell for nitrous system
Holley blue pump and regulator for nitrous set @7psi
Hooker super competition 1 3/4" headers
Duel 3" exhaust and Spintech mufflers
Aeromotive 500 fuel pump 10an stainless lines
Aeromotive return style regulator set at 15psi
Summit pressure regulator set @ 9psi
GM performance magnetic pick-up distributor
MSD Digital 6 plus ign. amplifier
i think that covers it
mike
Old Apr 3, 2004 | 12:45 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
sorry for the late reply. i have our cars in the car show this weekend at the old ernst bldg. come by i'll be there most all day this weekend
mike
Old Apr 3, 2004 | 10:01 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
mike
I'll try to stop by. I get off work 2day at 5:30 so if its still open I'll stop by... If its closed for the night, I'll be there tomorrow.
Old Apr 4, 2004 | 09:48 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
dante if you were there sorry i missed you . thats about the time we went for dinner sat. nite . i won a trophy for th e best 80's modified
mike
Old Apr 5, 2004 | 09:34 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Sweet. I tried to make it over there on Sat 4 lunch but didn't realize there was an entrance fee and didn't have much cash at the time
Congrats on the trophy!
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
