Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
My first 12 second time!
Old Aug 7, 2004 | 01:04 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well I finally broke into the the 12's tonight with one of my runs, I was getting a little pissed off there because I kept getting 13.0X times, then I let my car cool off for a couple of hours and thats when it happened.
Reaction: .576
60' : 2.216
E.T. : 12.998
MPH : 107.374
Just about the highest 12 second time you can get LOL
Old Aug 7, 2004 | 02:11 AM
darbleinad's Avatar
Car: 84 Trans Am
congratulations, man. thats frigging awesome. great work.
Old Aug 7, 2004 | 09:28 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Sweet
Old Aug 7, 2004 | 10:12 AM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
congrats shouldnt it be lower since you got the supercharger?
i pull 2.2 60ft's and cant get no where near that i cant even hit the 14's
Old Aug 7, 2004 | 11:09 AM
TexasLT1's Avatar
Car: '92 RS
Nice job. Definitely need to work on your 60' times. You should easily be able to get 2.0's on street tires, even lower on drag radials.
PhAnToMs - if you can't even hit 14's then you are not going to get much lower 60's because of lack of power. More power = lower 60's.
Old Aug 7, 2004 | 11:55 AM
Tony89GTA's Avatar
Car: 89 GTA
Thanks guys, actually I'am using nitto DR also just they don't prep the track on friday test and tune nights. Most of my other runs were in the 2.1x that night but ya I got to work on it, maybe I'll invest in some slicks. Funny thing is I get better traction on the street then at are track.
Old Aug 7, 2004 | 12:06 PM
EvilCartman's Avatar
Car: '82 Z28
Congrats on the time One of the techs said the same thing last time I was at the track about hooking up better on the street. No prep on the track, things start building up and it gets slick. Couple guys did put down some VHT themselves though.
Old Aug 7, 2004 | 04:13 PM
nick418's Avatar
Engine: L98, Hemi 6.2
i wish my car can hit the 12s
Old Aug 7, 2004 | 07:16 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Times look good, but how much boost is that running? I would have guessed higher traps, but not knocking you! Get some traction and run some mid 12s!
Old Aug 7, 2004 | 08:13 PM
daverr's Avatar
hey i compared your times to mine .im amazed that we both ran the same trap speed.
tonygta(manual trans) ---- heres mine(89 gta auto trans)
60' -- 2.216 ---- 1.886 - .330
330'--5.699 ---- 5.318 - . 381
1/8---8.535 ---- 8.168 - .367
MPH--86.923 ---- 86.40 +.52mph
1000'--10.954 ---- 10.640 - .314
E.T.---12.998 ---- 12.738 - .260
MPH--107.374 ---- 107.37
if we both raced u would be gaining on me.
i could really see the difference between the auto and stick.Looks like u could really be in the mid 12`s if u cut 1.88 60 ft time like i did.The auto cuts good 60ft time realatively easy, but u can see how torque converter slippage takes a toll at the top end.Practice your launch technique,use slick and you`ll have a near mid 12 timeslip.
Old Aug 7, 2004 | 09:52 PM
Tony89GTA's Avatar
Car: 89 GTA
Hey daverr nice times, what are all your mods to get you into the 12's.
Old Aug 7, 2004 | 10:16 PM
Tony89GTA's Avatar
Car: 89 GTA
The blower produces 5psi/4000rpm 8psi/5000 and 10psi/5500 rpm which is where I was shifting at. I'am probably over revving it a little since a stock car makes its HP at 4500 but I figure with the blower and intake I should be up to at lest 5000 rpm with my HP peek, I need more track time or a dyno to be sure. I probably should have a higher mph but hey what can you do , except make more boost I have a 3.4" pulley waiting to go in, just need to find a belt for it.
Old Aug 7, 2004 | 10:22 PM
daverr's Avatar
its 89 GTA .with a 350 (.060)(450hp) 13-1 , 294S comp cams ,world product heads (motown),10 inch converter,th350, ford 9 inch with 4.11, ET drag slicks 26x10
Old Aug 7, 2004 | 11:18 PM
Tony89GTA's Avatar
Car: 89 GTA
it's always nice here about another fast GTA!
Whats your car weigh in at, mines 3860 with me and a full tank of gas.
Old Aug 7, 2004 | 11:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ouch that's heavy! Lose a couple of hundred pounds and 12's would be easier
Old Aug 8, 2004 | 12:33 AM
daverr's Avatar
i havent weighed my car yet.I might weigh it tomorrow.ill get back to u on that.
Old Aug 8, 2004 | 12:40 AM
Tony89GTA's Avatar
Car: 89 GTA
Who me or the car?
Old Aug 8, 2004 | 03:03 AM
Car: '82 Z28
What kind of exhaust are you running and what's the stall on the converter? Best mph out of my setup has only been 103 so far
Old Aug 8, 2004 | 11:39 AM
daverr's Avatar
I run open headers (conventional headman headers).The torque converter i run is 10 inch coan converter that stalls at around 3500 rpms.As far as u running 103 mph, u might be running at a higher elevation than I.Since we both have the same cam,Where do u shift at??, i had my engine on the dyno and peaked at 6600 rpms @ 450hp.u also have slightly less compression than i do, so u might be down 20-30hp.Also your car could weigh more than mine.As u can see there alot of variables.do me a favor i`d like to compare your cranking compression pressure vs mine (185~190psi). Whats your total advance timing??
Old Aug 8, 2004 | 03:18 PM
MdFormula350's Avatar
congrats..
Old Aug 8, 2004 | 04:36 PM
Car: '82 Z28
Humm.. I'm going to be trying just running mine out the y-pipe next time out after making the exhaust removable (shop welded everything in place) Track elevation is 500 feet but usually pretty warm. I shift at 7k right now but can feel the car nose over around 6800-6900, tried shifting at 6500 and went slower. But then again, 2 runs after my best time both got slower never tried a lower shift point again that night. Taking the car to a chassis dyno this month to find out what numbers it puts down. Timing is locked out at 36* and best mph from that was 102.5 I think. The 103 run was with total at 39* not locked out. I'll go do a compression test in a bit, gotta go eat something first hehe.
Old Aug 8, 2004 | 05:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Congrats!
I got my first 13-sec. timeslip two years ago in Topeka. With the mods done since, I've made a few 13-sec runs up here now, which would be in the 12's at the lower altitude.
I'm hoping to qualify for the Div V ET finals next month, which will be in Topeka, to get a shot at one. Of course, if I do, I'll have to back off because I'll be running the Sportsman class which has a 13.00 min dial.
That first milestone time slip sure is sweet, though.
Old Aug 8, 2004 | 05:42 PM
daverr's Avatar
ok i weighed my at 3361 ,thats with an almost empty tank and without me 175 pounds.so i figure on track day . i should weigh in between 3500-3600 pounds.oh by the i weighed my car using 12 bathroom scales lol,so i could be off a little. let the bashing begin lol
Old Aug 8, 2004 | 06:23 PM
Car: '82 Z28
Well chit, looks like my compression isn't as high as I thought it would be just did two cylinders and they were both 125 psi which is around 9.5:1 I was hoping it would have been up around 10:1 And how did you manage the bathroom scale thing? LOL
Old Aug 8, 2004 | 08:45 PM
daverr's Avatar
looks like your compression is a bit low....that could explain why your trap speed is lower than mine, also u car weighs a bit more than mine.
as far as bathroom scale thing.this is what i did i bought the same scale from a few different walgreens in my neighborhood,because each store had only 2,some had 3.so now i have 12 in total ,each has a max of 300lbs.Then i went to home depot bought a 10 foot 4x6(around that size).cut it into 4 equal pieces,i had the guy in homedepot do it for me.so under each wheel i had a wood board on top of 3 scales.then i just added up all 12 scales and came up with the weight.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
