Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
another "what will it run" question.
Old Oct 16, 2004 | 09:25 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
355 L98, AFR heads portmatched, TPiS 216/226 cam (ZZ9), Portmatched LPE Superram base, runners and plenum, BBK 58mm TB, SVO 30# injectors, shorty headers, ORY, magnaflow exhaust, 9-bolt 3.27 rear, 700R4 with 3k stall, LCA's, drag shocks/springs, drag radials, MSD billet distributor, coil, and 6AL.
Old Oct 16, 2004 | 03:22 PM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
Should be running low to mid 12's. Very close to the combo I want to put in my car and I've seen similar ones run the times above. Very Nice!
Old Oct 16, 2004 | 03:44 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I'm going to guess 12.5 in the 1/4 mile.
Old Oct 16, 2004 | 05:15 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the E/T doesnt mean **** as to what the motor is making....its all about trap speed...id say you have 110-112 in it...thats anywere from a low 13 to a hi 11.....trap speed is the true indicator of what its capable of...but seeing as you have DR's a stall and some rear suspension parts, and you can lauch the crap out of it, then you should be able to knock off 12 3's and 4's....
Old Oct 16, 2004 | 09:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Any reason you went with the ZZ9 cam? I would do something like 219/219 cam or custom grind with no split pattern grind. AFR's have good exhaust port and can run single pattern. Thats what everyone has told me so far cuz thats the same setup i want to run. Low 12's is best i heard but elevens is possible when tunned right and good traction.
Old Oct 17, 2004 | 03:37 PM
Engine: LB9/383
I bought the motor used from a buddy and that's the cam he had in it. I was planning on putting in a 219/219 b/c he told me it had a blower cam in it. I took it out and saw that it was a ZZ9, so I figured I'll use that for now and next winter I'm gonna port the heads and slap in a bigger custom cam.
Old Oct 29, 2004 | 05:54 PM
megaracerx's Avatar
my guess as to what you'll be running is....faster then my car!
Old Oct 29, 2004 | 07:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd knock the 3.27 gears as poor gears but I ran high 11's with some 3.27's at 117 mph when I had a 383 SBC. 3.90's would have been a lot better for me because of the amount of hp I was producing. I was crossing the finish line well below my shift point so the gearing was all wrong but it was still good runs with 3.27 gears.
I'd catch everyone off guard. They'd 60 foot beter than me and pull away in the first 1/8 mile but I'd catch up and shoot by them at the finish faster than most cars would.
Old Oct 29, 2004 | 08:34 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
TTA850 was cutting 1.5's with 3.08 gears
Old Oct 30, 2004 | 08:50 AM
Engine: LB9/383
The 3.27's were put on the list b/c thats whats in it now. I'm waiting to put the 12 bolt in until after I get the motor in. It's sitting in the crate with the upgraded Eaton posi unit, 33 spline axles and 3.73's.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
