Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Another what it capable of
Old Feb 8, 2005 | 11:12 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
I know better than to ask. But I'll do it any way. What is it capable to run in the 1/4? Here is the combo
84 camaro
3500 lb with driver
355 SB
517 hp with 460 lbs torque @ flywheel
Tremec tko 2 trans
17Lb. Mcleod alum flywheel/clutch twin iron disk assembly
12 bolt 3.90 gears
SFC weld in
LCA Relocation brackets
Spohn Tork arm
heim end R LCAs
Koni yellow shocks
MT ET streets 10 wide tire
Old Feb 8, 2005 | 11:28 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
With me driving or you?
Old Feb 8, 2005 | 11:57 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
11.65@117mph. ill assume you are able to get a 1.6 60". happy motoring buddy, now take it to the track and adjust for altitude.........
Old Feb 8, 2005 | 11:58 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
DynoDim er Don
I was asking a simple question on the forum and don't need no smart *** ex SLOW Stock racer who can't run faster than 13's to give me static!
Old Feb 9, 2005 | 12:01 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't think it would be that low but low 12's or high 11's is possible if you can get that power to the ground.
Old Feb 9, 2005 | 05:42 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Thanks for the input gentlemen I hope everything turns out good
Old Feb 10, 2005 | 02:09 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Those engine dyno #'s or desktop dyno #'s, big difference...
Old Feb 10, 2005 | 03:20 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Engine dyno! At Verbrancic Bros. in Ontario, Cal.
10.3 to 1 comp.
91 octane 76 pump gas.
NA and no power adder
old fashion solid lifter cam
Old Feb 10, 2005 | 10:19 AM
10.3 to 1 comp.
Awesome, good numbers what are the specs on the motor?
John in RI
Car Audio
Sep 10, 2015 11:24 PM
Gta-Paladin
Dec 10, 2001 12:48 AM
Ions91Z28
Jul 27, 2001 01:12 PM
ae420gd
Feb 26, 2001 11:00 PM
R.O.B.
Aftermarket Product Review
Nov 16, 2000 08:19 PM
