stunt pump gas 383
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
stunt pump gas 383
Who got fast pump gas 383 with a similar setup as mine .What is your combo and what ares your track time ?
I hesitate on builting a 355 (cr9.75)or 383 (cr11.0)... my goal is to run around 11.6 on motor & 10.7 on 125 hp of juice so i am loockin for a nice setup !!!
I alredy got:
-victor jr heads 215 (2.08-1.60)
-super victor intake
-CC XE XR286R (248-254dur&.576-.582@1.5lift)
-CC 818-16 solid roller lifter
-CC Pro magnum roller rocker 1.6
-Holley HP carb
I had trade my TH 700 for a '76 TH350 th (I will install a TCI pro super kit and a super street fighter stall 3500-3800)
Stock rear end with a locker & 4.10 MT ET drag 28x9x15
Thanx
I alredy got:
-Holley HP carb
Thanx
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
That is very close to my combination. I have a 383 with brodix track1's and a crower solid roller with 248 and 252 duration.The intake is a team G with an850 speed demon carb. I also am running a th350 with a superstreetfighter and 3.73 gears out back with a 26x9 slick.I run 11.2 - 11.4 @ 119-120 mph and my motor is actually very tired(8 or 9 years old ). I expect to pick up a few more tenths next year after I freshen it up.
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
mine is very similar. lightly ported vic jrs, custom ground solid roller for bottle. with 3.73s has gone 11.50 and needs some adjustments. everything else should be in sig if not ill put the rest up as well.
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Check my signature for my setup. Its a reliable combo that has excellent street manners. I'm still running power brakes and power steering.
Car: 91 firebird
Axle/Gears: 4.30
the headers are stahl headers. i really think that are great but the price for them isnt so great. i fell into a hell of a deal when i got them. As far as jbenge said my car has excellent street manners as well and there is alot left in this car seeings everything was built around the bottle. im waiting for the weather to cool down around here and when it does i will try to get it in the 20s or 30s on motor and then im confident (based on some testing ive already done the car will dip into the very low 10's maybe a 9.99 on a small shot.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
in da sig
Car: 91 firebird
Axle/Gears: 4.30
IHI has had one of the better running 383's on the board and if you end up having trouble once its together he can help get you on track.
Car: '88 IROC-Z medium orange metallic
Built a 383 for my buddy's Nova, Eagle crank/rods, forged flat tops, 11.2:1, AFR CNC'd heads, 236/242, Air Gap intake an Holley 650. Turbo 350 trans and 4.10 10 bolt. Made 515 on our engine dyno and runs 11.5x's.
I'm anxious to see what mine runs, similar setup with 10.5:1 and smaller cam.
12.17 with the list below, need some suspension tuning and more gear/converter. Car has no a/c or power steering. Front swaybar removed ran on M/T Street radials. Stock torque arm, KYB shocks/struts, lakewood LCA's.
383, 5.7" rod
eagle crank/rods
10.25:1 CR
Internally balanced and fully blueprinted
AFR 195's, hand done chambers 270cfm @ .550"
Custom ISKY cam, just a hair bigger than a Hot Cam
Air Gap intake
Holley 650 w/half shafted baseplate
MSD billet distributor and 6AL box.
383, 5.7" rod
eagle crank/rods
10.25:1 CR
Air Gap intake
Originally posted by Dialed_In
12.17 with the list below, need some suspension tuning and more gear/converter. Car has no a/c or power steering. Front swaybar removed ran on M/T Street radials. Stock torque arm, KYB shocks/struts, lakewood LCA's. 2800 stall and 3.42's. It needs a bit more stall and some 3.73's.
383, 5.7" rod
eagle crank/rods
10.25:1 CR
Air Gap intake
383, 5.7" rod
eagle crank/rods
10.25:1 CR
Air Gap intake
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
