Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Back to the track soon...
Old Mar 30, 2006 | 03:54 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Well the track opens back up tomorrow, and i want to get down there. Last season i pulled a 13.5 at 99. This time I got some slicks, and i am hoping i can get better traction. Anyone think I can get some better times? Thanks
89 Iroc L98
FlowMaster Cat-Back, Catco cat, EdelBrock Headers, EdelBrock Intake Manifold and Runners [Both ported], Air Foil, TB Bypass, Plenum Ported, AFPR, Gutted Air Boxs, K&N Filter, HyperTech Chip , 160 Thermo, Re-mapped Injectors, MSN Ignition, Accel Rotor, Beefed Alternator, Modded MAF, 3.42 Rear End, And some new Slicks.
Old Mar 30, 2006 | 06:07 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
What was your 60' with out the slicks?
Old Mar 30, 2006 | 06:26 PM
MdFormula350's Avatar
yeah Id say with a 99 mph trap speed, u could see 13.3 or 13.4's with great traction.
Old Mar 30, 2006 | 06:36 PM
Car: ws6
Engine: ls1
Transmission: m6
1.891
Old Mar 30, 2006 | 07:02 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
honestly, i'd only expect about 1-2 tenths drop in et with the slicks. those are some stellar 60' times for street tires.
Old Mar 30, 2006 | 07:31 PM
Car: ws6
Engine: ls1
Transmission: m6
I just want to get a low 13 and trap a little better.
Old Mar 30, 2006 | 07:57 PM
Car: ws6
Engine: ls1
Transmission: m6
n/m
Old Mar 30, 2006 | 08:08 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Those are real good 60' times for street tires so im assuming that they are the same diameter tires i would say 13.2's or 13.3's. You will probably trap the same if not a little bit lower with the slicks from my experience.
Old Mar 30, 2006 | 08:36 PM
Car: ws6
Engine: ls1
Transmission: m6
I highly doubt I will see 13.2's, unless i get some other mods. Maybe if everything goes PERFECT. Conditions/air, low tire pressure, little fuel, insane traction.
Old Apr 2, 2006 | 01:37 PM
Car: ws6
Engine: ls1
Transmission: m6
Not 2 bad
Well, it didnt go too bad. The best run of the day was a 13.471 at 100.54. The weather was around 56-60 degrees. Next time I go i am going to get an edge converter with a 2800 stall, and hopefully a zz9 cam. Thanks for all your responses. If you have any other comments speak up. Later...
Old Apr 2, 2006 | 07:35 PM
Car: ws6
Engine: ls1
Transmission: m6
nm
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
