Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
First time out and need opinions
Old Aug 4, 2006 | 11:18 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Last weekend I ran a 12.52@111.1 with a 1.9 60ft, in 95 degree heat with high humidity. First time I ever raced with drag radials. I've got a supercharged 350 with virtually NO suspension modifications other than lowering springs (which probably is not good for the rear end) and subframe connectors.
With better DRs and a cooler day I'm thinking I might hit 11.9, but what should I _absolutely_ have done to the suspension at this point. The next time I go out I plan on reinstalling the stock springs in the rear.
Old Aug 4, 2006 | 12:41 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Nice ride and times!
Where did you find that low mile beauty?
I would say LCAs & reloc brackets since you're lowered, instead of swapping springs.
What were your times before the ATI setup?
15psi of boost? yowsa!
Old Aug 4, 2006 | 12:59 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
first of all, i do the rear end first. That stock 10 bolt is gonna grenade on u pretty soon. Good moser 12bolt wil fit ur application perfectly. Now depending if this a daily driver or a all out drag car, I say for gears 3.23 for street or 3.73 for drag use Is this gonna be ur daily street driven car or its built strictly for drag racing?
Old Aug 4, 2006 | 01:08 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
It's the 9 bolt, the strong one (from what I have read).
I'm only interested in an 11 second timeslip. I don't care if it runs 11.9 or 11.0, I just want one 11 sec slip to my name and then I'll probably not race it much more after that if ever.
The reason I was thinking just swapping out rear springs is, well, because I have the stock ones and it's easy and free.
It'd be great if I could just swap out the springs, run some new DRs and race on a 65 degree day and belt out an 11.99999. If I can't, though, then the launch is where I'm going to spend the least amount of money to get there from here the way I figure it.
Old Aug 4, 2006 | 01:15 PM
Car: '89 GTA
He has the Borg Warner 9-bolt like I do.
It's perfectly fine into the 11's and beyond.
I don't think stock springs are the answer to 11's, although cooler weather will help a bit.
You asked what you should absolutely have done to the susp.
LCAs/brackets are my advice, torque arm wouldn't hurt either.
See my Q's above too. ^
Old Aug 4, 2006 | 01:32 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Where I found it:
My mechanic built this car for his son 8 years ago. He lost interest in the car soon after, and has been trying to sell it to me since 2000. I finally gave in
Engine has forged internals and compression lowered to 8:1 to handle the large amounts of boost. The work was done at the same time the supercharger was put on, so the only times it posted were on a bone-stock set up...mid 14s.
Old Aug 4, 2006 | 01:48 PM
Car: '89 GTA
Awesome, built for boost with stock TPI on top still.
Have you had any tuning done? 11's could be had with just that I'm sure.
I know a guy that does TPI custom chips/dyno tuning in North Canton, Ohio if interested.
I'm running a full bolt-on L98 with heads & mild cam, only mid-13's so far.
Just curious what I'd run with about 6-7psi boost.
I'd love to have your mid-12 times with half the psi.
Old Aug 4, 2006 | 02:13 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Yeah, it has a custom prom. I didn't get much of a chance to fool around with the fuel pressure at boost because it was so hot when I ran. I also only saw 10lbs or so- I see 13lbs just fooling around in cooler temperatures, with a max between 15-16, again when it is cool.
I'll probably get the LCAs and brackets, new DRs, and wait to go back to the track until september. I'm hoping I won't have any trouble hitting my goal with good ambient temps at that point.
onefreakz
May 14, 2018 12:15 PM
camaro71633
Sep 1, 2015 10:24 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
Thornburg
Aug 25, 2015 01:46 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
