Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Roll cage rules
Old Feb 28, 2007 | 08:34 PM
BadIROCZ's Avatar
Car: 89 Iroc Z
Engine: Gen 1 350
Axle/Gears: Stock and shitty
Roll cage rules
will a 6 point cage be sufficient enough to run low 10's it will be bolted in or welded if need be
greg
Old Feb 28, 2007 | 08:47 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Old Mar 7, 2007 | 08:45 AM
dcboyz4eva's Avatar
Car: 01 gti, and 89 irocz
Engine: 355cu
Axle/Gears: 373
but can you weld it in your self or do you have to have a qualified welder weld it in? and what kind of qualified welder?
Old Mar 7, 2007 | 08:53 AM
Night rider327's Avatar
Car: 1988 Camaro
If you know how to weld and have a MIG or TIG welder with sheilding gas you can do it yourself. NHRA says NO stick welds, or gasless flux core welding. Only Mig or Tig
I installed a 10 point cage, with swing out sidebars in mine.
I had a cheap flux core gassless welder. My idea was to cut/fit all the bars in and tack them into place with my welder then call a pro out to mig weld all the joints.
Ended up the pro welders wanted too damn much to do it. $50 less than I could buy a new hobart mig and rent a argon/c02 bottle for.. So I bought a 140 amp hobart welder and rented a tank.
Ground all the flux core welds off and weldedit all my self with the mig.
Here's two, 2 pages each albums of my install from start to finish.
http://rides.webshots.com/album/535313828Bdmlrh
http://rides.webshots.com/album/547435884gnIcmV
Old Mar 7, 2007 | 09:31 AM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
thank you i just bought a cage and i wondered about that, my cousin i guess will help me hes certified to weld...underwater..but ive been welding for a wile...but yeah thanks for the pictures there a big help to
Old Mar 7, 2007 | 06:41 PM
BadIROCZ's Avatar
Car: 89 Iroc Z
Engine: Gen 1 350
what i need to know i guess is an 8 point cage legal for a 10.5 car?
Old Mar 7, 2007 | 07:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 5 point roll bar is legal to 10.0 as long as your firewall and floor are unmodified. Putting in wheel tubs at the rear is not considered a floor modification. Just don't relocate the firewall or cut out the floor to make an access area to remove the tranny.
Most people put in the passenger door bar to make it a 6 point roll bar. Adding the tubes under the rear crossbar and running them down to the driveshaft tunnel area makes it an 8 point roll bar. After that, you get into a full cage classification.
Old Mar 8, 2007 | 04:58 PM
BadIROCZ's Avatar
Car: 89 Iroc Z
Engine: Gen 1 350
stephen you are the man thats all i needed to know thanks man im instaling an 8 point in my 85 iroc stock floor and everything
Old Mar 24, 2007 | 07:19 PM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
Re: Roll cage rules
do i have to use the stell plate in my iroc...or can i weld the roll bars straight to the car?
Old Mar 24, 2007 | 08:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Roll cage rules
The only time the tubes can be welded straight to the car is if they're welded directly to the frame. Third gens do not have a frame so you must weld the plates to the floor then weld the tubes to the plates. Depending where you position the plates, they can also be bolted to the floor with a 6 x 6 x 1/8" plate on the top and bottom of the floor and a minimum of four 3/8" bolts through each plate. Because of the floor contours, it's hard to bolt the plates into a third gen to position the tubes in a functional position.
You can not weld the tubes directly to the sheet metal. Well, you can but only if you plan on driving only on the street since it will offer no rollover protection and won't pass a tech inspection.
Old Mar 24, 2007 | 09:51 PM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
Re: Roll cage rules
thanks for the info
Old Mar 25, 2007 | 06:18 PM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
Re: Roll cage rules
ok another question i have the 8 pt set up....can i use the bars the cnnect to the drive tunnle that would normally make it 8 when used with the door bars instead of the door bars? i guess im saying could i have a 6pt without using the bars that run by the doors
Old Mar 25, 2007 | 06:22 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Roll cage rules
No you can not get by with out at least the drvers side bar or a five point. I have both side bars swing out and when im not at the track I take them out.
Old Mar 26, 2007 | 01:15 PM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
Re: Roll cage rules
but i can run up to a 10 sec pass with just a passanger side? or is it a driver side?
Old Mar 26, 2007 | 02:20 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Re: Roll cage rules
A single bar on the driver's side is good to 10.00.
Old Mar 26, 2007 | 06:57 PM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
Re: Roll cage rules
but is a single bar on the passanger side the same or dose it have to be the driver side?
Old Mar 26, 2007 | 08:41 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
Re: Roll cage rules
It MUST be the Drivers side, no exceptions. If you got a 8 point then why wouldnt you just installe the whole thing?
Old Mar 27, 2007 | 08:38 AM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
Re: Roll cage rules
...i duno i was just seeing what i could do, but thanks again for all the info
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
