Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
ZZ4 ET Question
Old Oct 20, 2007 | 02:37 PM
Profootbrake's Avatar
Car: 92 camaro Z28
ZZ4 ET Question
how fast are the cars running the zz4 with tpi
Old Oct 20, 2007 | 11:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: ZZ4 ET Question
Mine went 13.21 at 107.19.
Old Oct 23, 2007 | 07:57 PM
Car: 92 camaro Z28
Re: ZZ4 ET Question
Thanks for the reply i hope mine runs that well
Old Oct 23, 2007 | 08:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: ZZ4 ET Question
are you talking about taking a ZZ4 crate and adding a stock TPI system to it? or are you talking about the ZZ4 hotcam based 357hp Scoggin dickey crate TPI motor?
stock ZZ4 with TPI should go mid 13's easily with right gearing/suspension and stall. Mine stock L98 with exhaust/stall/gears/slicks went 13.63 and another guy here has gone much faster...13.2's are looking like a possibility for him. Bigger runners/base should make that car go mid lower 13's
the hotcam crate will put down more power, as long as you use aftermarket TPI stuff. stock tpi will choke it. i can see 12's at 105-107 or so as long as everything else is in check
Old Oct 25, 2007 | 02:59 PM
Car: 92 camaro Z28
Re: ZZ4 ET Question
Orr89RocZ thanks for the reply What I have is a zz4 with a edelbrock lower intake and SLP runners using the stock 305 injectors and throttle body. I’m using shorty headers and a cat back system for the exhaust. Its has a 2400 stall with 3.42 gears With the old engine the car ran about 13.5s in 1/4 and 8.5s in the 1/8. I'll find out what it runs soon with the new engine
Old Oct 25, 2007 | 03:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: ZZ4 ET Question
that combo could use more stall but should still run well on good tires. ZZ4 has slightly better heads and cam than fbody L98's so should run a few tenths quicker for sure. I've seen stock TPI L98s with stall/gears doing mid 13's. you'll probly get lower 13's with that setup
Old Oct 25, 2007 | 04:53 PM
86 IROC's Avatar
Re: ZZ4 ET Question
A friend of mine had a ZZ4 in an 89' IROC dual cat car. Mail order tune, K&N's, flowmaster muffler, BFG DR's... all else was stock. Car was consistently running 13.40's @ 99 MPH.
Old Oct 28, 2007 | 10:43 AM
Car: 92 camaro Z28
Re: ZZ4 ET Question
well i found out what it runs last night on an 1/8 mile track the best of the night was 8.599 @79.79mph 1.84 60ft.
Old Oct 28, 2007 | 03:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: ZZ4 ET Question
thats good for mid 13's at near 99-100mph in the 1/4
lt500r55
Sep 1, 2021 01:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
redmaroz
Aug 16, 2015 11:40 PM
