Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
One more try...
Old Nov 9, 2007 | 11:59 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
One more try...
I posted this a few days ago but it wasn't quite as detailed and didn't really get any replies.
The car is an 88 camaro with a carbed 355, 350 trans, Hedman headers, sfc's, posi, 3.73's, moroso fuel cooler, and a little weight reduction. Back seats are gone along with all the rear carpeting and plastic trim in the hatch. A/C is gone.
The engine is a 355 with a comp cam with around 220-230 duration at .50 and lift of about .480. The heads are the 67cc World SR Torquers. It is topped off with an Edelbrock RPM manifold and a 750 Demon Carb.
The tranny is a turbo 350 with a shift kit. It has an 11" TCI breakaway stall.
I know the carb is too big, but I don't know alot about carbs. Can't it be jetted down to work with my setup, if so, what do I need?
How will my car perform with this setup and how will it perform after fixing the carb issue?
Old Nov 9, 2007 | 01:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: One more try...
Nothing wrong with a 750 on a 355. Unless you plan of doing daily street driving only with no intention of any kind of performance, I wouldn't recommend anything smaller.
As for jetting, it doesn't have anything to do with the carb size. The goal is to jet to give the best air/fuel ratio during normal driving conditions. Depending on the exact carb models, a 750 carb could have 82 jets and an 850 could have 78 jets to achieve this. Bigger carbs allow more air into the engine which can broaden the power curve.
Best air/fuel ratio is around 14.7:1. At WOT it should be slightly rich around 12:1.
A bit more cam could really wake up the engine.
Old Nov 9, 2007 | 02:26 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: One more try...
Thanks for the info. What kind of 1/4 mile times would my current setup produce? What is a better cam choice and how much of a gain should I expect?
Old Nov 9, 2007 | 02:29 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: One more try...
I'd guess mid to low 13's if you tune the heel out of it.
Old Nov 9, 2007 | 06:01 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: One more try...
lol what running on 7 cylinders theres 350's with bolt ons running high 12's. Id say he should run mid to high 12's with a nice tune and stall
Old Nov 10, 2007 | 09:50 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Re: One more try...
I'd say low 13's. On a perfect day, great traction, and a tailwind, 12s are possible.
Old Nov 12, 2007 | 12:58 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: One more try...
I'd say high 12's if you can dead hook the car. Good luck, let us know how it goes.
Old Nov 13, 2007 | 07:56 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: One more try...
Just picked up some Scorpion 1.6 roller rockers. Just need an alternator, plugs, and gaskets to get it all together.
Old Nov 13, 2007 | 02:13 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: One more try...
Which plugs should I go with? I already have MSD super conductor wires.
Floridacamaro
May 20, 2015 02:49 PM
Chevy2035
Dec 21, 2014 05:42 PM
88Trans-am
Jul 25, 2014 09:04 AM
Terrence1725
Jan 25, 2014 05:44 PM
