Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
really bad wheel hooping.
Old Feb 15, 2008 | 03:58 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i put a lock right locker in my car and changed my shock. now i have really bad wheel hooping. why?
Old Feb 15, 2008 | 04:22 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: really bad wheel hooping.
shock change possibly
Old Feb 15, 2008 | 10:18 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
did you have anykind of posi before? if it was just a one legger before , and now it spins both. you just have the next problem to work on. are the shocks adjustable? change tire pressure?
Old Feb 15, 2008 | 10:41 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Your Lower Control Arm bushings might be wore out. Get some new bushings or aftermarket LCA's.
Old Feb 15, 2008 | 11:04 PM
intex1982's Avatar
new bushings
it had a posi till i tear it out
Old Feb 15, 2008 | 11:31 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
That's your tires loading and unloading, good way to break stuff. Adjusting your weight transfer, shock rebound front and rear, tire pressure. Make the car swat in the rear so if you break something it's the weak link not the result of hammering on it. Also make sure the pinion angle is not jumping around that will add to the issues.
Does the car go straight or to one side if you start out straight ?
Last edited by 85gulstrandTA; Feb 15, 2008 at 11:32 PM. Reason: Automerged Doublepost
Old Feb 22, 2008 | 12:15 PM
TB2's Avatar
TB2
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
The problem is your getting more traction now than you were before, and the extra force is causing the wheel hop. What you need to do is lower the mounting point of the Lower Control Arms on the rear axle with some relocation brackets. Some good Lower Control Arms with good bushings would also help.
Old Feb 22, 2008 | 04:17 PM
intex1982's Avatar
i have those same ones on my car now
Old Feb 22, 2008 | 06:42 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
which hole are the lca's in? what's the rest of the suspension look like? if i recall correctly, don't you have aftermarket lca's? what kinda rear shocks were you running? what are you running now?
fyi: those lockers suck...they don't like to have ANY kind of abuse put to them:
Old Feb 22, 2008 | 06:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
All this time I though wheels & tires were hoops. . .
Wheel hop is the suspension springing back on the axle and tires. Stamped u-section control arms + rubber bushings = recipe for wheel hop. If you haven't boxed your lower control arms and installed poly bushings, or installed aftermarket tubular LCAs with poly bushings, now's the time.
Old Feb 22, 2008 | 09:09 PM
intex1982's Avatar
i have boxed with with rubber bushings
Old Feb 22, 2008 | 09:26 PM
intex1982's Avatar
which hole are the lca's in? bottom hole. what's the rest of the suspension look like?reinforced torque arm , boxed lca and penhard. if i recall correctly, don't you have aftermarket lca's?no what kinda rear shocks were you running? new stock. (what are you running now? huh?)
Old Feb 22, 2008 | 09:56 PM
mw66nova's Avatar
Engine: 7.0L
ok, i'm thinking you might put the old shocks back in. i'm running monroe replacements, but they're like 6 years old and have like 50K plus on them. just try that to see if that helps. otherwise, maybe the bushings are wore out? do you still have the rubber trans mount? how bout the torque arm mount?
Old Feb 22, 2008 | 10:06 PM
intex1982's Avatar
use the old shocks? i have soild t/a mount to crossmember and i still have rubber trans mount. and if i get on it going down the road kicks to either side not spining. kinda hard to explain. feels like something is lose.
Old Feb 22, 2008 | 11:55 PM
mw66nova's Avatar
Engine: 7.0L
it sounds like some worn bushings. but those lockers will do wierd things too, cause they don't lock until power is applied.
redmaroz
Apr 25, 2017 07:14 AM
Scamo-2.8
May 20, 2016 07:01 PM
dyeager535
Aug 28, 2015 08:10 AM
B_Dubya
Aug 26, 2015 05:09 PM
