Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
weight reduction tip and 1/4 mile tips?
Old Oct 21, 2008 | 05:33 AM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
im running a carbed 305 with a 700r4 with a shift kit and higher than stock converter but nothing big as a daily driver and 1/4 mile track car. i have eliminated everything to do with the ac and no heater either and added a harwood lift off hood. anything else i can do? im trying to get my 1/4 mile times down alittle and get my mph up. any other tips on 1/4 mile time would be appreciated.
Old Nov 4, 2008 | 06:39 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: weight reduction tip and 1/4 mile tips?
get rid of the stock rear gears, they are killing you. Go with at least a 3.42
Old Nov 4, 2008 | 07:08 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Anything done to the motor?
Old Nov 5, 2008 | 04:09 PM
deadman's Avatar
Car: 89 camaro
roller cam, 400sbc heads,edelbrock intake and carb.
Old Nov 5, 2008 | 05:58 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Whats the specs on the cam.
Why 400 heads, the compression will be low because they have big combustion chambers.
Old Nov 5, 2008 | 07:07 PM
deadman's Avatar
Car: 89 camaro
the heads are a set i had that fit my intake. the engine is from a 91 tbi camaro and change to a carb. the engine was built .20 over stock and stock cam.... i didnt build the engine i bought it to get me out of a bind.
Old Nov 6, 2008 | 06:01 AM
87_TA's Avatar
Light weight wheels are a great way, losing rotating weight is always worth alot. Front rear bumpers supports, s10 manual steering box, get rid of power brake booster, front swaybar, ductwork under dash, tubular k-member/A-Arms, rear trailing arms... Lots of stuff depending how far you want to go..
But right now you have lots of power options first, almost anything you do to the engine right now will gain you et - that when its fun.. The higher stall converter will lose weight also, and more rotational weight, light weight radiator depending if you have a copper one or the plastic/alum.. Lots of things. Ohh aluminumdriveshaft is another goodone, that will work off any ls1 car and most LT1s had them in 96 and some prior due to dealer recall.
Where do you live in SW PA? I am 15 miles south of Pittsburgh, Elizabeth. Race at PRP?
Old Nov 6, 2008 | 04:01 PM
deadman's Avatar
Car: 89 camaro
im in new stanton....... and raced at pittsburgh raceway park
Old Nov 6, 2008 | 05:25 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Lose the heads, try and find some 416 (car) or 601 (truck) 305 heads. Any head earlier than 86 wll fit that intake, and the ones from 86-95 but you have to grind the center intake holes to line them up.
Old Nov 6, 2008 | 05:33 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
If you still have the FI parts I'd go to a Holley stealth ram and get some decent Aluminum heads Trick Flow is good but anybodies will be better than what you have.
Frozer!!!
Jan 19, 2024 04:55 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Warlocksirix
Sep 3, 2015 12:26 PM
neekolzun
Aug 24, 2015 04:59 PM
BurlyChev
Aug 22, 2015 11:42 AM
