Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
rim backspace
Old Nov 9, 2008 | 08:56 PM
92stealthramz28's Avatar
Car: 92 Camaro z28
Engine: 427 sb
Transmission: th400
Axle/Gears: 9"/4.30
rim backspace
I have a moser 9" stock lenght. Im getting 15x10 rim with 295 radial tire. What backspacing would I need to use to have the tires tuck inside the fender? Thanks, Ronnie
Old Nov 9, 2008 | 09:00 PM
Stephen's Avatar
Car: 87 GTA
Re: rim backspace
I had 295s on my 92 with the stock 4.5" bs that tucked real well.
Old Nov 9, 2008 | 09:38 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: rim backspace
not on a 15x10 wheel. the 5.5" backspacing will get it right at or slightly under the fender lip, most people are going to a 6.5" backspacing and it tucks the tires nicely, but inner fender modifications are needed (hehe, get out the BFH!)
Old Nov 9, 2008 | 10:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: rim backspace
I second the 5.5" with a 10" rim. I ran 29.5 x 10.5 slicks on them and they tucked under the fenders nicely however the tire height required some inner fender modifications. A shorter, more common 26" tall tire doesn't have those issues.
Old Nov 10, 2008 | 01:51 AM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Re: rim backspace
Also if you go the 15x10 with 6.5 BS to tuck them more there will be modifications to the inner fenders as stated but some people are saying you need offset lower control arms as well. Im not sure if it is a must or not but I believe so.
Old Nov 10, 2008 | 02:49 AM
mw66nova's Avatar
Engine: 7.0L
Re: rim backspace
i think that really depends on tire size...i believe radialtireking is running a 295/65/15 on a 15x10 with 6.5" backspacing with minimal work and regular tubular lca's...xpndbl3 is also running the same backspacing with regular style lca's as well...
Old Nov 10, 2008 | 06:17 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: rim backspace
6.5 back spacing and I found my air hammer to work the best at reshaping the inner wheel well you will also need tubular lower controll arms.
Old Nov 10, 2008 | 07:19 AM
Car: 92 Camaro z28
Engine: 427 sb
Transmission: th400
Axle/Gears: 9"/4.30
Re: rim backspace
Thanks for the info guys. Just needed to get an idea before I ordered my rims.
Old Jan 4, 2009 | 10:35 PM
SKYNOVERYA550's Avatar
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
Re: rim backspace
so is there any one that is certain! you new tubular lca's??
Old Jan 4, 2009 | 11:34 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: rim backspace
no I have rod ended everything in my suspension all chro moly tubular with offset bushings on the LCAs. For the size tire I'm running I definitely needed the offset.
Old Jan 5, 2009 | 12:59 AM
JesasaurusRex's Avatar
Re: rim backspace
15x10 with 6.5" backspacing will be fine with a 295, 10" wheel with 5.5 looks disgusting . Get the hammer.
Old Jan 5, 2009 | 07:22 AM
mw66nova's Avatar
Engine: 7.0L
Re: rim backspace
whoops...i'm a dumbass! lol....
to the OP: make sure you listen to these guys...i'm running a small tire on a 15x10 with 6.5" backspacing (just a 275/60) so i got away with alot less problems than the guys running the 12" wide tires.
Old Jan 5, 2009 | 02:24 PM
83 Crossfire TA's Avatar
Re: rim backspace
on a 10" wide wheel, 6" of backspacing will locate the tire approximately where a stock 15 wheel does, 6.5" will put it a 1/2" further in, 5.5" will put it a 1/2" further out. The problem is finding a 6" backspacing.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
