Manual steering box
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Manual steering box
I want to convert to a S10 manual box, anyone got and PNs or suggestions? What else is there to swap? Or is it straight forward as i think it is?
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
Re: Manual steering box
i got an s10 manual box on my car, don't have the part number on me cause the car is in my dads shop, but all i had to do was grind it abit and bolt it on. you will know where to grind when you test fit the box, i would tell you where to grind but i don't remember and i would have to pull the box to tell you.
I will get the part number from it so your search is alittle easier, I'll try and post it tommorrow.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i asked for a 87 S10 4cyl 2wd manual gearbox from my local autozone. just bought a reman'd one since the 2 out of a junkyard had way too much slop in them.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Alright, i remember my 88 S10 had the manual setup. How is it driving on the street? I know my S10 weighed less than my 89 but from a dead stop it was not too bad to turn, i will be adding some front weigt to the car, i hope it doesnt make it much more than the S10 was.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
True, but man, if you REALLY need to stop...you are in bad shape.
Car: 91 Bird
Engine: Pontiac 500 + CID
Transmission: 3 speed auto
Quay, did a Vega box on mine. it has worked great...I have small tires as well. I also have a cute to help me stop (never had to pull it yet)...LOL PS my car is stock weight.
Car: 1982 Camaro, 1985 Z28
Engine: 383, 305
Transmission: TH350, T-5
Mines from a 93 s-10, skinnies and no sway bar..no grinding, just have to remove the sway bar bracketry. About 7 turns lock to lock but fine when moving.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
From what I UNDERSTAND, There are two different s10 steering boxes, only one of which will work, the way to tell the difference is how many bolts hold the top cover on, one has three and the other one has four, I forget which one you need, but later today I can go out to my car and look for you. I know I got my box from an early 90s s10.
As far as steering effort, I never notice the manual box, except occasionally when I have to pull into a real tight parking spot, than you notice how many times you have to turn the wheel.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I picked up a manual S10 box recently from a friend and it bolted right up, no problems to the linkage. I haven't attached the column yet, but did test fit the ragjoint and it was tight but fit. As for the number of bolts holding the top cover on, I'm 99% sure it's got 4. I may put the power box back in though. I'm not really needing the weight savings so much as the car is not a serious strip car. I'd rather have it turn quick for the twisty backroads around me than lose the weight from the nose for quicker ET's.
It's nice to know the steering effort is the same. I was worried about that because I have to parallel park my Camaro every day when I drive it.
Car: 02 SS
i want that old muscle car exp., no ac, no ps,
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
the 82 and 83 box is the one you dont want.
if it has a 4 bolt top you should be good.
just ask for a late 80's model and youll be golden.
steering isnt bad, you have to muscle it around in tight spaces.
changed to a pinto race last year and it almost feels like the car has power steering again.
lil tight from a dead stop, but anything rolling is cake.
anyone have any problems with their steering wheel not being straight and the turn signals not working right????????????????????????????????????????????
Car: 1984 Z28
turn signals have nothing to do with a box swap and if your steering wheel is off then you need a alignment to straighten it back out.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
its a good guess. would make sense since your steering wheel cam is off.
turn the wheel one way or the other(wheels turned) and see if your blinkers work then.
unless the wheel spun and broke the cam in the steering wheel. possible, but not likely.
try turning the wheels and see if you get anything.
undo the shaft and move the wheel if thats the issue.
good luck.
LMK... im curious.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I just went to the local pick a part and dropped the box off a 92 S10, only change i had to make was swapping pitman arms, other than that bolted right up.
Not nearly as easy as power steering, but not that bad. The dart lil m block i have puts me at the same weight as a BBC and i can drive around just fine. I will eventually get a power steering pump like they use on stock cars though, super tiny, light, draws minimal power...and then i can go back to one finger driving and most of all, a quick ratio steering box so just in case the car gets out of shape i'm not spinnging the wheel 7 turns one way and back to try and regain control...just 3 lock to lock LOL!!
Engine: 383, 305
I had to use my original pitman arm. once I had the box and steering wheel centered it was a little off due to the # of turns diff, I just adjusted the tie rod sleeves to center the wheel.
ok guys this is what i've done so far: when first installed the box my wheel was off center about 90 degrees, and i think that was because the sleeve that goes on the shaft coming out of the box has one flat on it and that is how they lined up and from that point till now my turn signal timing has been off. one thing that i didn't try was trying to rotate the rag joint because to be honest i don't know if you can or if it would help. i did move my steering wheel so that is was straight, i just took it off the splines and rotated the adapter to as close to center as possible, steering wheel is a grant if anyone wanted to know
so with all that said if anyone has anymore ideas i can try let me have them because the turn signal thing is very annoying
also thanks for the ideas and explanation that have already been posted. i will give them a try when i get out to the shop.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i had this issue on another setup and just moved my steering wheel.
it was a grant 5 bolt type setup.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
