Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Came down hard
Old May 8, 2011 | 04:58 PM
JesasaurusRex's Avatar
Came down hard
Think this fuel pressure safety switch is doin me in, have had problems with this before and after moving the fpss from after the regulator to before it seems to still be giving me issues. Just lost power at the top of the wheel stand and that was pretty much all she wrote. Need to look at the front suspension too since it bump steers pretty bad (you can see it in the video if you look closely enough). Long story short, cracked a motor mount mounting location on the block and bent the motor mount pretty good. The good news is I think that's all the damage that was done and some motor plates will pretty much remedy the current situation. Pics later, video now
It's a diesel conversion for those who donno the car
http://www.youtube.com/watch?v=CcUsa9HoMic
Sorry, can't figure out how to embed on this forum
Old May 8, 2011 | 05:15 PM
DIGGLER's Avatar
Re: Came down hard
i dont run one.
my car is in need of alignment again too. last time out stood it up and its fubar. i think im going to put some training wheels on it for testing.
Old May 8, 2011 | 05:56 PM
Re: Came down hard
nooooooooooooooooooooooo
Old May 8, 2011 | 06:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Came down hard
Ouch. I'm sure if something happened when my front end was in the air, I'd also cause damage.
Wheelie bars are a safety device. If they're set so low that the front end doesn't rise at all, they'll probably slow you down unless you have a full tube chassis car with a really good chassis setup. If they're set 4-6" off the ground, you'll still pull the wheels and if you lose power like you did, the front end will still come crashing down. The wheelie bars will just prevent you from going up on the bumper.
I'm sure if I did the same thing, I'd be really considering wheelie bars too.
Old May 8, 2011 | 07:58 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Came down hard
ouch!!!!!
i would be throwing that fpss in the garbage if it were mine.....seems like they cause more headache than they're worth
Old May 9, 2011 | 12:18 AM
Re: Came down hard
was fun while it lasted
Old May 9, 2011 | 06:45 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Came down hard
yikes. hope it didn't hurt your new headers
Old May 9, 2011 | 11:50 AM
Shagwell's Avatar
Car: projects.......
Re: Came down hard
Can't view vids from work, but the pic says it all.
Sucks to happen, but at least you have some footage of it for some LOLs after all is said an done. I got greedy doing a "grudge" run with a friend a while back and took the bumper off the back of the car.....didn't drop it though, so no major damage, but no pics or video to take the sting off of it.
Old May 9, 2011 | 02:16 PM
EvilCartman's Avatar
Car: '82 Z28
Re: Came down hard
Ditch the fuel safety switch
Old May 9, 2011 | 03:42 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Came down hard
Ouch. What about some "oh ****" bars for under the car? Was it madman who was making those? They were tubular steel bars that provided a crush cushion for hard landings like yours. Header savers... Haha
Old May 9, 2011 | 05:14 PM
mw66nova's Avatar
Engine: 7.0L
Re: Came down hard
"Save Your *** Bars". madman makes them for 4th gens
Old May 9, 2011 | 06:28 PM
Re: Came down hard
nope, they sit up higher than the hookers did, oil pans fine too believe it or not, even tho it sits about a 1/2" lower than the k member. Donno how that works but i'll take it . Stock k member ftmfw!!
As for wheelie bars...no thanks, that sh*ts for race cars
I like this picture better
Old May 9, 2011 | 06:30 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Came down hard
haha jesse, at least your day was still better than mine at the track.
Old May 9, 2011 | 06:34 PM
Re: Came down hard
welding with trans cable brings a whole new meaning to wire feed
Old May 9, 2011 | 10:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Came down hard
You sure got lots of grandstand shots in a hurry.
Old May 11, 2011 | 10:43 AM
Shagwell's Avatar
Re: Came down hard
It's amazing the number of people who will come up to you in the pits after you put it on the bumper. - I'd been posting solid times all evening w/o anyone noticing, knocked the bumper off on the line and took it out past 400' on the rears and instantly became a celebrity.
I didn't even get any pics/vids to take the sting off the newly required body work.
Old May 13, 2011 | 05:54 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Came down hard
yep even with it not shutting off you need to bring it in a little slower, or get that suspension under control, its all hook!
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
