Will slicks fit.....
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Will a set of 26x10.5 Et slicks on 15 inch rims fit in my stock wheel wells??? Its a 1991 Camaro Rs. Thanks for any help!
Car: 1991 Camaro RS
Re: Will slicks fit.....
i dont rember what the rs wheels are but i dont think they were 8inch wide
if somone knows the correct offset offhand u can just goto pepboys and buy 2 cheap steel wheels to put them on
on my car i had a weld draglite 15x8 with 5.5 bs and had to use a 1/4 inch spacer to get a 28x10.5x15 to clear good .
im sure the 26x10.5 will clear much easier though
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not sure on the f-body factory rims but the majority of them are either 6 or 7" wide. Other than specialty rims like from a Corvette or something like that, it's unlikely a factory rim will be 8" wide.
Car: 1991 Camaro RS
Ok thanks for the tips... yea dave there 2 inches shorter so Im hoping there gonna fit. 8'' wide is ok for a width on the rim to fit the tire though right???
yeah i belive 8" is the minum recomended rim for that tire the shorter tire will have less sidewall buldge, and thats the reason i had to use a 1/4 spacer on mine even fater hannering the bumpstop back and hammering a tiny bit of the inner fender
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I'd buy a 10" rim regardless if you're running slicks and don't own the rims yet. In 5.5bs or if you feel like cutting and hammering a bunch a 6.5bs will tuck the tire more.
id have him stay at 8 inch wide , only reason he will be running the 10.5 tire is beacause hes getting them super super cheap. down the road the car only needs a 26x9 tire. its all my car ever needed and he dont plan on going as fast as i do.
so the bigger heavier tire is just going to hurt the thing out of the hole anyways
my car goes 1.84 60 on a street tire and 1.7 60 on the 28x10.5 tire im sure it would go 1.6 or better on the 26x9
if he had a stick is say go with the 10inch wide rim and keep the 10.5w tire on it but stock converter and auto trans isnt going to need anything more then a 9inch tire hell i bet a 8inch wide tire would get the job done with launches under 14 psi
do the sizes between the et street and drag really differ that much?
the tires i ran were 28x10.5w et drags and man they were big
28x10.5w
compared to my 26x9 hoosier
28x10.5w
Car: 87 IROC L98
A drag tire width is measured across the tread area. A 10.5 will have approximately 10.5" of rubber width. It depends on the actual tire specs. The W tires are really a lie. They generally have 1/2" or 1" more width and many 10.5 classes have banned the W tires. Depending on the rim width the tire is mounted on, a 10.5" slick could be up to 12" wide across the section of the tire.
A DOT tire, the 10.5" width is the section width. The tread of a 10.5 DOT tire is closer to 8".
Figuring out how well a tire will fit under the fenders isn't just about the rim width and backspace. The DOT and drag slick will require different clearances if the same spec tire is used. A 10.5 DOT tire fits roughly the same as a 9" slick.
Car: 1991 Camaro RS
Ok thanks for the info and tips. I do know that the tires arent much wider then 8inches. Thats why my friends basically giving them to me, since hes going up to 26X10.5 slicks. Those 26X10.5 ET slicks arent nearly as wide. I looked it up and saw that 7.5-8.5 inch rims are reccomended for these Micky-T ET slicks. So hopefully I can find a set of cheep rims that will work for what I need. Weight doesnt bother me of the rims, or the sprun weight. Im just trying to get a faster car that still some what consistant and hope that I can still cut a .0xx light with these new mods.
I dont need too much tire, I just wana save the wear on my street tires and launch better. I had problems launching sometimes last fall when my car was running 16's in is N/A form, Now that Ive added the turbo set up and hopefully can run a 13-14's second pass. I need to make sure that I can spool up the turbo a little at the line and not just fry my street radials.
Track opens in April up here in Ohio, can wait to see what this little V6 will do with 250-275Hp weighing in at 3250 with me in the car... probly more like 3300 with me in the car since I added the turbo and other things that weight it down a little.
Im definitly the only idiot with a turboed V6 thirdgen at that track so its definitly a rare set up that will catch a eye or 2, only if I can make a good time though. I definitly hope to if all goes as planed.
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
I've been running a 26x10 slick on 15 x 8 old vette wheels with no clearance issues at all. Cars been 11.3et with a 1.56 60 foot on them.
Car: 1991 Camaro RS
Will 15x8'' rims with a bolt patternt of 5x4 3/4 with 0 off set work??
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
26-10.0x15 MT ET Drags on 15x8 on 4.5" BS rims.
Are you sure about the 10.5 part?
yeah im a lil slow tongiht i caught that after i posted
Car: 1991 Camaro RS
Yea 26x10.5 Micky. Tom. ET street slicks for 15'' rims. But I could have been told wrong. Friend just sent me a pic/told me the size really quick(I might have rembered wrong) and said I could come over and pick them up for cheep since hes gettin 10.5W slicks.
So a 0' offset wont work though??? 4.5" BS is what ill need regardless?
Car: 1984 Z28
ET STREET can be 10.5 IIRC
ET drag is 26x10.0
ET drag is 26x10.0
Car: 1984 Z28
but the 26x10.5 ET street is like a 26x8.5 ET drag in actual size
if you're going to get a 10" wide wheel, do the 6.5bs..or that sh*t will look ugly as *****
get a 9" wheel with 5.5bs, that way you can be lazy like me and not have an ugly car
Car: 1991 Camaro RS
Well i got a shot at getting some 15x8 with 0 offset(4" backspacing) free...Im hoping those will get the job done as im so broke it hurts after that turbo build I just completed.
they'll stick out 1/2" less than a 10" wheel with 5.5bs
OP this is how you wanna do it
x8" wheel = 4.5bs
x9" wheel = 5.5bs
x10" wheel = 6.5bs
all of these will provide the same amount of stick out, any less back spacing on any of these sizes will push the wheel more out of the wheel well
x8" wheel = 4.5bs
x9" wheel = 5.5bs
x10" wheel = 6.5bs
Car: 1991 Camaro RS
Ok thanks every one for the help on the slicks/rim sizes!
Got to datalog today and measured 10-90MPH in 12.5 seconds on 11psi of boost.(Im not sure how accurate tunerpro Rt is at timing but its a idea I guess) . Not bad for a V6....Cant wait to see how it does at the track. I know launching is going to be alot different as Ive never raced a turboed car at the track before.
I hope my tranny doesnt go boom or the rear end at that matter.....easy launches might be slower but wont gernade my lil 10 bolt.
1 Post
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Ironic though, because he was looking for slicks yesterday at the season opener in Norwalk. I think the ones he got last year half-used are about done lol. Mark, what about Nate's slicks? If I remember correctly, wasn't he buying new slicks this year? He mentioned giving you his old ones.
2 months and a year
Car: 1991 Camaro RS
Anderew, nate couldnt afford new ones..lol Beacuase of the new motorhome.
Im looking into going to summit in 2 weeks and picking up a slick, rim combo.
#42
if ur going for new slicks get something wider then 9.5 in a full slick
id say go get a 26 or 28x9 but i dont know how well they will hookup when u launch that thing off the 2 step, with ur fairly stock suspension
if u can get a 10 inch wide slick in 26 inch that would be pretty nice, the 28x10.5's on my car were pretty dang heavy ( rotational wieght)
#43
it's not my car, and not my place, but if my opinion means anything, i think that for a budget wheel, these look super slick on thirdgens
http://www.summitracing.com/parts/su...s/media/images
#44
edit just checked and i can get 15x4's for the fronts , but is 1.75 inch backspace right?
#47
i could on the other hand get the 28x10.5's to break loose launching on the antilag , which at full boost were talking over 450ftlbs on launch , but they were also used slicks so didnt hook as good as they should of
#48
Car: 1991 Camaro RS
I hope some 28x10's won't hurt me too bad. I got my eyes set on picking up a pair of hos. ones this weekend. One season on them and there 50 bucks from a friend. Those should hold me off for a season. But now I just need to get rims that make is so they fit in the wells good.
#49
if ur going to get new rims get somethng in 9-10inch wide
what i have found with used slicks that have sat during the off season is that they need a really good burnout or 2 before they really work well.
something about the rubber compound getting harder when it sits in the off season
#50
Car: 1991 Camaro RS
Ok dave.
Im looking to get some 9inch wide rims with a 5.5 inch back space.
