first time @ track...take a look, i need help
1st run:
R/T... .697
60'... 2.539
330... 7.410
1/8... 11.399
MPH... 61.85
1000... 14.822
1/4... 17.728
MPH... 77.25
2nd run:
R/T... .589
60'... 2.557
330... 7.437
1/8... 11.400
MPH... 62.05
1000... 14.821
1/4... 17.709
MPH... 77.95
ok, now i knew i was not anywhere close to 14's but 17.7x....WTF... help me i'm about to cry..
mod's in signature
TIA,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, AFPR, 60psi. Fuel Pressure gauge, 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
R/T... .697
60'... 2.539
330... 7.410
1/8... 11.399
MPH... 61.85
1000... 14.822
1/4... 17.728
MPH... 77.25
2nd run:
R/T... .589
60'... 2.557
330... 7.437
1/8... 11.400
MPH... 62.05
1000... 14.821
1/4... 17.709
MPH... 77.95
mod's in signature
TIA,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
Mods:
Car: 87Z
Engine: ?
Transmission: A4
The 60' times are killing you you need to try a lower launch RPM. You must be sping the crap out of your tires. Other than that I'm new to these cars and dont know alot about the TBI cars. My mods and times are in my Sig. I run 2.1X 60's.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47
Best 15.414 @ 87.47
i see you have an afpr on the car. what kind of pressure are you running. the car needs about 11psi, 12 at the most.
also is the car an auto or a stick. in stock form you want to launch at no more than 1k rpm. the torque curves comes up very quick in our cars (peaks around 2k) so starting further below it will help your 60's.
drag racing is all done at the tree and in the first sixty feet. if you want to maod you car work on traction and gearing and then look for power.
lata
tim
91 Camaro RS-LO3,Auto.
14.390 @ 94.99mph
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall), 36mm Front 25mm Rear Sway Bars, Eibach Pro Kit Springs, Bilstein Shocks and Struts, Steve Spohn Rear Rig( all rod ends), Poly Front Bushings, Baer Track Kit Front Brakes W/ Baer Disc Rears, 17x9 4th Gen SS Wheels, Ported TB, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
lata
tim
14.390 @ 94.99mph
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Whoh I missed that. You have a TBI "Ultimate TBI mods" and are running 60 PSI fuel pressure? It's amazing the injectors haven't locked up. Try bringing it down to 15 PSI max. 40-60 PSI is for multiport TPI fuel systems. It needs that much pressure to feed 8 injectors and 60 is probably way too high for that also.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
ok, went back to the track to try again. ran it 3 times.
R/T 60' 330 1/8 MPH 1000 1/4 MPH
0.527 2.575 7.505 11.51 61.48 14.957 17.869 77.26
0.451 2.576 7.458 11.43 61.98 14.852 17.752 77.47
0.587 2.532 7.383 11.331 62.21 14.742 17.663 77.83
i Droped a .1 thats the best i can do. be it is very consistant
RS
RS
Car: 87 IROC L98
The 2.5xx tell me you have a bad traction problem. That will effect ET. You might be about to get into the 16's with better traction.
The 77.xx mph is a result in HP. It's consistant with your previous runs. It's also very low for a third gen. When you do any changes to the car, watch the mph. It will indicate whether the changes increased or decreased HP.
you might want to start by checking your timing. I am not sure what the TBI cars like to run at but a normal carborated small block likes around 32-38 total timing. you might start off by setting your initial timing at 12 and going from there. the more you advance it the more lowend you will get (to a point of course). Pull your plugs and see what color they are. If they are black then you are, you want them to be a light brown color or even a white. You can mess with you plug gap and try different heat ranges also to pick up some time but by the sound of things and your MPH you have a problem somewhere. How old is the motor? Is it burning any oil?
