Just got back from the track heres my crappy times!
This was my first time at the track but here is my best timeslip:
reaction: .416
60 ft: 2.245
660 ft: 10.212
E.T.: 15.950
MPH: 85.482
Is this a good time for my mods? What would my times be with 3.73 gears and 120 shot nitrous? Thanks
MODS:
K&N FILTERCHARGER
K&N X-TREME FLOW TOP PLATE
FLOWMASTER 80 SERIES MUFFLER
EDELBROCK T.E.S. HEADERS
HYPERTECH THERMOMASTER CHIP
160* THERMOSTAT
GUTTED CAT
reaction: .416
60 ft: 2.245
660 ft: 10.212
E.T.: 15.950
MPH: 85.482
MODS:
K&N FILTERCHARGER
160* THERMOSTAT
GUTTED CAT
Car: 88 IROC
Transmission: auto
With almost same mods as yours (except headers, chip, and i have 180 stat) i run a 16.75 1/4 mile @ 85.44mph w/ a 2.79 60' time , and it was also my first time at the track. Do you have a manual or auto? Its amazing how close our mph are. I got you beat by a couple hundreds of a second on the mph, he he
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As long as you can hook up the nitrous alone is good for about 1.5 seconds. You'd be about mid 14's with NOS. The gears might get you into the 13's with NOS.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 87Z
Engine: ?
Transmission: A4
<font face="Verdana, Arial" size="2">Originally posted by 88'camaro305TBI:
</font>
</font>
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, and 170* Stat.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
“Fallen But Not Forgotten”
Car: '89 Firebird
Engine: 7.0L
<font face="Verdana, Arial" size="2">Originally posted by 305tbilo3:
What would my times be with 3.73 gears and 120 shot nitrous?</font>
My bone stock TBI 305 with 2.73's ran 16.11. I made 8 passes all within a tenth but I also have years of bracket racing experience with my Nova, so I know how to be consistent.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Car: 88 IROC
Transmission: auto
No, the 60' time is not normal, i managed to get a 2.4x before, but i got a worse overall time. I think the gears and the peg leg are the biggest problem. When i don't drop the clutch and just floor it, it will move very slowly off the line and then gets up and goes. With the 3.42 gears i have in there right now, i don't drop the clutch and it moves real quick from the start with just a little bit of tire squeal. Still don't have posi though.
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
DEAD *** bone stock 1986 peanut cammed TA auto with 2.7 rear gears.....
15.92 @ 84 mph, 2.17 60's.
Even the exhaust is factory installed!
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I think I may know some reason why your going so slow. How my car was. If I hook up and get good traction I would get like high 15's. But if I sping the tires. I mean rev it up as far as it would go. ANd then floor it with the tires spinning I would hit like mid 15's. I think it was because of my bad low end. Yes a LO3 with no low end. (I had 350 heads on my car)
Chris
91 RS 305 TBI
Eternal Rev
Chris
91 RS 305 TBI
Eternal Rev
