Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
10 point cage kit?
Old Apr 30, 2012 | 08:54 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
10 point cage kit?
Who makes the best fitting kit? Pics greatly appreciated! Thinking of welding in a kit to get me back in the seat and if I need something more serious down the road at least it's fairly cheap and no big deal to cut out. I want something that goes through the dash and would like door bars to clear arm rests.
Thanks,
Aaron
Old Apr 30, 2012 | 09:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 10 point cage kit?
There are many kits available. S&W is a good choice.
Old Apr 30, 2012 | 09:13 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
X2 for the S&W. They also make one that clears the armrests. I know that Spohn sells them, and at a fairly reasonable price.
Old May 1, 2012 | 09:10 AM
Car: 91 firebird
Axle/Gears: 4.30
The s&w is what I have been looking at does anyone have pics of the kit going in and also finished?
Old May 1, 2012 | 08:13 PM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Here's a pic of mine while I was painting it. Pardon the brown dust everywhere...it was from the primer I used and, well, it's a long story lol. It's a S&W, and it fit pretty good, I just had to do the typical cutting to length and notching. I think the through dash bars were like 40 or 50 bucks extra...it's been a long time now and I can't remember. I don't have any installation pics that would really be helpful.
Old May 1, 2012 | 11:55 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Im running the Jegster kit.
Old May 4, 2012 | 09:29 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I did a S+W kit and it wasn't as drop in as it seems. The halo would have landed in the view of the drivers window and the rear extension bars will land in the trunk (No good).
The door bars also were rebent in order to have full clearance of the door rests. There was little bit of re bending to make the S+W kit but overall I don't think the fabricator had a real difficulties putting it in.
If I did it again, I would find a qualified fabricator (which I have) and let him bend up his own cage using his own materials (chromoly). The cost may not even be any more than suppling your own kit and the builder will have more room to manipulate it his own way.
You also should consider doing subframe connectors and tying the cage to the frame.
Old May 30, 2012 | 07:41 AM
BBCpoweredZ28's Avatar
Did those seat "stands" off the crossbar come with the kit or did you add them yourself?
Old May 30, 2012 | 09:57 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
those are additional of course, typically you just buy the steel and make them yourself
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
