how fast would 425hp and 425 torque in a 84 trans am?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i have 3.73 one wheel peel right now
but i will change it to posi when soon and i am gonna get a 2500 stall
and some kind of sub frame connectors or something
i have 245/60/R15's right now
in a 700R4
anyone give me a rough estimate?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
in a 700R4
Mods-
K&N Air filter
Hooker Cat-Back
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Assuming that's RWHP and you can get the power to the ground it should run mid to high 11's. That's also assuming the car with driver weighs around 3500 pounds.
In the real world I would guestimate it might run high 12's or low 13's.
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I'm gonna say low 12's to mid 11'2 but that is after the WEAK 700r4 bites the dust with that much torque, can you say bye bye 2nd gear shifts!!!! I know i wasted mine in 2 weeks!! also wasted 2 TCI "street fighter" 700r4's
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.532
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
195cc AFR's
Hooker super comp L/T headers
Street Driven Daily!!!
Kansas F-Body Association Member
Best 60 ft : 1.97
Best 1/4 : 12.532
Steve Spohn
Rear Suspension
Autometer guages
195cc AFR's
Car: 1984 Trans Am
Engine: Vortec 355
well it is a engine kit so its prolly flywheel hp
and what can i run to make my car handle it???
would it b hard to drop in a manual if i had to?
A manual conversion is no fun. You'd be better off going with a th350 or th400 conversion. You'll loose your overdrive, but as long as you dont drive on the highway too much, it shouldnt be bad. It is kind of fun to think about putting a manual in there, but when it comes time to buy parts/do work it sucks. With that kind of power what manual would you run anyway? T56? Muncie?
Just remember that if you plan on making that much power, plan on spending a good deal of money on your suspension/drivetrain. If you could get 425hp and get it to hook correctly, I'd say low low 12's or high 11's.
Car: 1984 Trans Am
Engine: Vortec 355
well thtas great that if i wanted to i could run 12's
but i only wanna run like mid to low 13's
i pretty much want a car that can kick sideways and do a looooooong burnout when mashed to the floor!
lol
lol
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
