Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
header help
Old Aug 18, 2012 | 10:12 PM
ssgtgaines's Avatar
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
header help
I have an 86 firebird. 385cu in . Have 13 to 1. Cam is. 669 lift custom ground crower. Dart 230 heads no porting. A professional products single plane with a 850 cfm quick fuel carb. Currently i have hooker 1 3/4 long tubes. Currently have a best of 10.56 at 130. I believe the headers are a bit small. I want to get some ed quays. My question is does anyone agree with me about header size? What size should i get. And how much of a gain do you think i will see. I plan on going to a larger cuin. Small block in a year or two.
Old Aug 19, 2012 | 10:21 AM
JesasaurusRex's Avatar
Re: header help
doubt you'll get the gain you think you will with a larger header, that being said, yes probably small for your application
Old Aug 19, 2012 | 11:51 AM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
I dont expect 9's or anyrhing if i could dop into the 10.4's that would be cool. Just wondwring if anyone has ever had this same situation. If its not gonna help me i dont want to drop a grand on them. Im to the point now i know i have to spend big money for any impovements. I just dont want to waste my money.
Old Aug 19, 2012 | 01:19 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: header help
Agreed, you might gain a tenth or 2.
But! I think you are at the limit of your headers.
Post a pic of your set-up. You running full exhaust? Or just open headers?
I am installing 1 7/8 Ed Quay headers as I type. The set-up is costing me more than I thought, but I have a lot of room for alot more HP
Old Aug 19, 2012 | 02:17 PM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
Open headers with a 12 inch turndown
Old Aug 19, 2012 | 02:19 PM
DIGGLER's Avatar
Re: header help
i would get the heads ported by tea or another GOOD cnc porter. would most likely pick up a good bit more power. i personally don't think bigger headers will pick you up much and would spend that money elsewhere. i've been 9.44 so far on the 1 3/4 hookers with some nitrous.
how is the 60's? is the converter/gear perfect?
Old Aug 19, 2012 | 02:43 PM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
Best 60 is 1.55 i know there is some improvement to be had there. I feel it should be in the 1.4's. Im using a 5000 stall from a buddy. Mine is out being restalled to 5500. That is what coan said i needed. Hopefullly ill get it back this week and be able to gdt a better 60. Gotta get a single digit pass this year. Even if i have to use a little n2 o. Hahaha
Old Aug 19, 2012 | 03:19 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: header help
been 1.48 and 10.40's on 1 5/8's long tubes so it can be done with what you have now and a little more work. But if all your looking for is peak hp then the larger tubes would be better to start with!
Im not sure about the ed quays yet I have been looking at a set myself but a lot of guys over on YB have had issues with them. Run a search there and you will see some pretty ugly pics.
Old Aug 20, 2012 | 10:39 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Axle/Gears: Aluminum Moser 3.89
Re: header help
I wouldn't say issues. The headers do not come finish welded on the flanges and most of the posters about Quay ( not YB people in general)over there have no idea how headers get made. Quay is a cheaper alternative than a custom set if you have some talent to finish the flanges. I believe I paid 659.00 for mine a few years ago and I had them finish weld my sbc and my bbc I had to finish myself. Now remember, Quay builds headers for his old school k-members and not for the aftermarket k-members so finish welding them will give you a better fit and help with more starter options. One thing he doesn't do is update his products.
the 1 3/4 are fine for what you have and I would not change until you are making 700 hp. The 15hp they may net you is just a .05 upgrade in nitrous jet. Scrap the intake for a Super Victor and port the heads. You may have 50-75 hp there.
Old Aug 20, 2012 | 10:23 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: header help
That guy was me with the EQ headers. They came to me UN-finished so I could move the pipes around for a better fit. Which I did have to move 1 pipe for better starter clearance. They fit awesome for a big tube header.
I would recommend them. Remember, the bigger the header, along with a stock k-member, the harder to fit in the car
Old Aug 22, 2012 | 10:13 PM
izcain's Avatar
Engine: 584
Re: header help
There have been alot more people then you with that were having "issues" most people see the "issues" for what they are...... a part that will need some tweaking/finishing. Glad you got them to fit well!
Planning on a set myself since they are about the best you can get for the kinda breathing some people need. Just plan on some finish welding! either that or I will just build the next set myself. I have a few sets out already for other cars just not one made yet for our cars.
Old Aug 22, 2012 | 10:20 PM
izcain's Avatar
Engine: 584
Re: header help
Agree with this 100% the intake and heads will net you a whole lot more!
Old Aug 23, 2012 | 09:56 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Re: header help
What do the heads flow and how much RPM are you turning through the traps?
Old Aug 23, 2012 | 04:55 PM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
Dont have numbers on the heads. They are just unported dart 230's. Trapping at around 6800
Old Aug 23, 2012 | 06:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Larger primaries tend to hurt low end power, so if you're trying to improve 60', that's the wrong way to go. Of course, a proper converter will take care of that issue.
You're a little over-carb'd, but that probably isn't hurting you too much. I would guess that a Victor Jr. would pick up power over your knock-off intake, though. Probably across the powerband.
Old Aug 23, 2012 | 08:30 PM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
The carb is what qick fuel told me i needed. I will change intakes to a victo this year. I agree with you on the 60 ft. I think for right now ill probably work on the 60's. Maybe if the moneys there i will get a set this winter. I want to build a 427 this winter. Gonna hit it with a 200 shot. I want to to see this thing go low 9's.
Old Aug 23, 2012 | 08:36 PM
Dialed_In's Avatar
Re: header help
Thats a good plan. Put the effort into the chassis for now. You're gonna need it with a 427.
Old Aug 23, 2012 | 08:49 PM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
Thats what im thinking
Old Aug 27, 2012 | 04:13 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Re: header help
Im considering going another direction with my turd if I do I have a freshly coated set of 1-7/8 stahl headers I would be selling.
Old Aug 28, 2012 | 06:21 AM
ssgtgaines's Avatar
Car: 86 firebird
Re: header help
Sweet let me know
Old Aug 28, 2012 | 07:07 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: header help
I have been more than happy with my Hooker 2210 super comps.. Even though I had to do a little cutting around the lower A-Arm.. Now I have finally pulled off the stock K-Frame and put a tubular K-frame and tubular A-arms with coil over shocks.. I will be installing them in the next few weeks.
Old Sep 8, 2012 | 10:26 AM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: header help
i run 10.1x with super comp 1 3/4 headers...i lost 20hp on the engine dyno from 1 7/8 but i didnt have the money for them. ill be getting a set of 1 3/4 to 1 7/8 soon enough.
big heads and carb kill 60'...thats a top end charge setup. converter will help..as long as trans and rear gearing is right. good luck!!
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
