Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Trans blanket or shield??
Old Sep 1, 2013 | 11:07 PM
Beeman's Avatar
Has anyone used a trans blanket or shield with stock floorboards and a Turbo 350? How did it fit, what brand did you use?
Old Sep 2, 2013 | 03:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Trans blanket or shield??
I had an rci blanket on my th400 for a day or two. My exhaust was too close and burnt it up. I know some folks use the nice csr carbon shields with good luck.
Old Sep 2, 2013 | 04:05 PM
JesasaurusRex's Avatar
I had the csr one, the bell housing bolts are a pita to get to. I'd do an ultra bell and a separate trans shield. Wanna say I'm using a tci one with my glide.
Old Sep 2, 2013 | 08:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
CSR full shield on my car but I also have a modified firewall and trans tunnel which makes accessing the bellhousing bolts a lot easier.
If you need a trans shield, you'll also require a flexplate shield. Even though using a blanket is easy, fitting a flexplate shield is normally difficult no matter what type or style you use.
As mentioned above, an UltraBell is the way to go if you can afford one but it still needs to be recertified or replaced every 5 years just like a trans/flexplate shield if you're running quick enough to require the shields.
Old Sep 25, 2013 | 07:06 PM
daverr's Avatar
This is the th400 I run in my car , it fits quite well in thirdgens.
Old Sep 25, 2013 | 07:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Csr shield on my th400. Slight clearancing on firewall/trans tunnel, but fits great, once you grind down the trans casting bosses as needed
Also had to trim the shield around the cooler outlet lines.
DO YOURSELF A FAVOR AND BOLT TRANS TO MOTOR BEFORE INSTALLING. If you are lucky enough to have motor out the car. that was easy. I have no idea how to install those bolts if you didnt atleast move the motor or seriously mod firewall/tunnel. Stock bolts were hard let alone an inch or so longer bolts
Old Sep 25, 2013 | 07:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I think every CSR shield is like that. The cooler line opening sucks. You need to modify the opening to run the cooler lines properly. Once the shield has been modified, you can't recertify it.
Not like the shield will fail to protect you after the SFI tag expires in 5 years. I have yet to see any tech inspector climb under a weekend bracket car to see if the required shield has a valid SFI decal on it. Running in national or divisional races however, they may just do that.
I really should get one of those Ultrabell bellhousings for my glide. With no rear trans mount, all the weight of the transmission is hanging off 6 bolts and a weak bellhousing casting. Not that the powerglide is very heavy to begin with.
Old Oct 3, 2013 | 09:38 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
What is the ET / MPH requirement for actually needing a trans shield?
forget I asked here is the NHRA rule:
Transmission shield meeting SFI Spec 4.1 mandatory on any car running 10.99 (*6.99) or quicker or any car exceeding 135 mph (217.2 km/h).
Automatic transmission flex plate meeting SFI Spec 29.1 and flex plate shield meeting SFI Spec 30.1 mandatory on cars running 9.99 (*6.39) or quicker or any car exceeding 135 mph (217.2 km/h). See General Regulations 2.14.
Old Oct 3, 2013 | 11:40 AM
FRMULA88's Avatar
Car: 1988 Formula
http://www.spohn.net/shop/1982-1992-...on-Shield.html
No brainer to me and looks to be the best one to use from the clearance and weight standpoint.
also I see a cut out on the right side for the cooler lines? I am going to see if I can find other views of this piece.
I should be running 10s ETs so better safe than sorry...
I have the engine out of the car so now is the time to do it..
Old Oct 3, 2013 | 12:16 PM
mw66nova's Avatar
Engine: 7.0L
i ned to get a scatterproof bellhousing and i guess i should look into wrapping my t56...
Eric-86sc
Apr 3, 2016 03:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Hello, Michael
Aug 20, 2015 03:19 PM
kyle5647
Aug 15, 2015 11:56 PM
