Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Anyone have access to a car lift?
Old Jul 9, 2003 | 05:17 PM
90RSRocks's Avatar
Car: White 1990 Camaro RS
Engine: LH0 V6
My car is leaking oil from the oil pan edge, and it looks like I just need to replace the gasket (at least I hope that's it). It would be alot easier with the car lifted though. Sooo.... back to the topic title: Anybody have access to such a thing? I'd be more than willing to :hail: or even dance like :lala: in return!
Old Jul 10, 2003 | 04:09 PM
90RSRocks's Avatar
Engine: LH0 V6
Never mind, I have it up far enough to see that it is not coming from the oil pan area, it is coming from the engine somewhere, and then dripping down and dropping on the ground from several points. Now I wish I had the know-how to tear things apart and see what's causing this. Grrr, frustrating.
Old Jul 10, 2003 | 04:24 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
hope its not your rear main, i bet its the valve covers, or the oil pressure sending unit, also check the back of the distributor, the gasket might be bad for some reason and might leak there.
good luck.
Old Jul 10, 2003 | 04:36 PM
90RSRocks's Avatar
Engine: LH0 V6
I don't know where to even start (heck I don't know where the things are you just mentioned), and unfortunately I have to leave for work in an hour so I can't fix it today. It is running fair, though it sometimes drops to a really low idle after it warms up now (at intersections, or when going under 10mph). I will try not to drive it more than absolutely neccessary until I can try to figure out where it's leaking.
It seems to be coming from the mid to rear of the engine almost at the bottom. The engine and everything under it is just coated in oil. It's not pretty.
Time for me to get out the Haynes and Chiltons books and learn up quick. Of course I had 4 of the last 5 days off, but it decided to break when I have to work 5 straight, lol.
Old Jul 11, 2003 | 03:17 AM
Squeeks83's Avatar
then it sounds like the rear intake gasket or your rear main, i sure hope for your sake it isnt the rear main, those SUCK, i just replaced it in my camaro, took me like 3 days of hard **** work. i did it with the engine int he car instead of takin it back out.
Old Jul 11, 2003 | 03:29 AM
age's Avatar
age
Car: 1992 Z28 1LE
umm... of all the listed possible gaskets, I think the oil pan gasket would be the worst to do. So, if it's any consolation, be happy that it ISN'T the oil pan gasket. The rear main is a breeze (esp. if you have a manual tranny and a one piece rear main) in comparison... and so are the valve cover gaskets. I've never had to get to the rear main with the automatic tranny, so I can imagine that it's just a little bit more work. But still..
If it is indeed the rear of the intake manifold that's leaking, then you can always start doing some port work to the plenum and base plate.
Old Jul 11, 2003 | 03:58 AM
Squeeks83's Avatar
yep, auto and a 2 peace rear main.
Old Jul 11, 2003 | 04:13 AM
90RSRocks's Avatar
Engine: LH0 V6
Well, I'm quickly learning how useless Haynes and Chilton's are. Unfortunately, my RS has an auto tranny and two piece main, it sounds like.
I kinda doubt that it's the rear main though, since I see lots of oil on both sides of the engine down low.
...then you can always start doing some port work to the plenum and base plate.
Sounds cool to me. What does it involve? Sorry I'm such a stupid newbie, I am still learning alot everyday about engines and our cars.
Old Jul 11, 2003 | 05:45 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
heh, if it is anything like portimg heads , it involves hours and hours of your time, a die grinder, and if you always forget ear plugs like i do possibly loss of your hearing.
Old Jul 11, 2003 | 12:35 PM
90RSRocks's Avatar
Engine: LH0 V6
Sounds like fun to me! What advantage is there to porting those areas? Better flow through the engine?
I am going to take the hood off for better access and then really try to figure out exactly where the leak is originating. I will probably have to disassemble the engine to some degree, so I might as well do some improvements while I have the engine torn apart.
Old Jul 11, 2003 | 12:36 PM
age's Avatar
age
Car: 1992 Z28 1LE
why don't you shampoo your engine, then watch for leaks
Old Jul 11, 2003 | 12:42 PM
Dewey316's Avatar
Car: 1990 Camaro RS
ruh roh,
has kelly been bitten by the HP bug????
yeah porting it will free up a few ponies for you to play around with
Old Jul 11, 2003 | 03:22 PM
90RSRocks's Avatar
Engine: LH0 V6
Hey thanks for the idea! I hadn't even considered cleaning it (because it's soooo dirty) until you suggested it. The grime/oil/goop that's caked on the underside of the engine looks like I may have to borrow the powerwasher from my store after I get off work tonight. That is the only thing that would really cut through all that gunk, I bet.
HP bug? Must've got me when I wasn't looking, lol. I could certainly afford to have some more ponies running loose in there, since my mighty 191ci engine is listed at 140hp (stock). I hate the fact my wife has more hp in her Ford, lmao.
Old Jul 11, 2003 | 06:15 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
We can fix that for you Kelly!
But watch out, that bug bites deep
-Schultzy
Old Jul 12, 2003 | 01:11 AM
age's Avatar
age
Car: 1992 Z28 1LE
Ok guys... our 3rd gen brother needs help here..
Old Jul 12, 2003 | 05:07 AM
90RSRocks's Avatar
Engine: LH0 V6
lol, I greatly appreciate any and all help! I couldn't powerwash it to remove the grime/oil mix (the washer was missing a piece). I will try it with the regular hose and some degreaser at home, see how it goes.
The SES light came on once on the way to work, then again on the way home tonight. The CPU stores the error codes doesn't it? I can't remember exactly how to pull the codes, so I will search for that info in the morning, it's too late now (3:30am).
I would definitely be up for some beefing up of my suspension and some major power-enhancing as soon as I fix this, so if anyone has advice I am sure listening. The one thing I know is to always listen to those who have forgotten more than I will probably ever learn about something, lol.
Old Jul 12, 2003 | 11:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
to pull the codes you put a paperclip between the two upper right aldl connection, and then turn the car to the 'on' position (do not start the car) , it will then flash the codes at you.
as for the 'fun' suggestions. since you aren't blessed with a full engine go TURBO!!!!
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
anesthes
Aug 8, 2015 09:37 PM
