Climate Question!
Car: 1987 IROC
Climate Question!
Im about to drive out there in my 87 Iroc, I have alot of mods done to it and Im afraid it wont be too winter climate friendly. I know its not friendly stock. What are the bad things or times I have to watch out for? Any tips?
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
So are you moving here? If so where at. Washington state or Oregon? If you are moving to Washington state your major counties Pierce, King Snohomish all have emissions testing.
Car: 1987 IROC
Im going to be in Snohomish county Everett Naval Base is where I stay. Im going to be there no later then the 26th of this month. I took the emission **** outta my car. My exhaust consists of Flowtech shorties,cat, flowmaster 40 series. Timing is at stock 6 degrees and afpr is set alittle bit higher. You think I have a chance?
Is there any places that you can pay for a sticker?lol
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
sadly, unlike california where you can (if you have the right connections) pass emissions without really doing so...here in WA (dunno about the west side)...east, we have dyno's setup just for emissions testing...and it's state run, not shop run. :P
Car: 1988 Iroz/Z28
Engine: 5.7 TPI
Transmission: auto
emission question
Being that you are Military you should be able to have an exemption. when I was at Fairchild AFB in Spokane I was exempt.
I would check into it with someone at your base.
Re: emission question
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
I registered all my Cars in Colville and live in spokane So I don't worry about smog emissions. but our gov. in Washington state want to adapt California emissons. I will vote against that
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
as far as being climat friendly the only thing that i can think would be a problem is an open air filter. it will get wet. may want to plug up the hole in the bottom of the airbox if you have done that mod. i have a rubber insert i put in during the winter and pull out in dry weather.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Axle/Gears: 3:27 Borg Warner
Emmision tests are zone specific. I have lived in both King and Pierce counties, Ag zones rule over all
(Never had to test, would pass anyway but I love to save money)
