Need help Fast
Need help Fast
I have a messed up Rod on my Camaro and has bent the crank.
It needs to be replaced NOW!!!!!
It has a 2.8L and a 700R4 so I need the same engine or something that will bolt right in and it needs to be cheap. Plus to make things worse I'm in Laramie Wyoming I'll pay for shiping as soon as I can afford one. So I need some advice do I replace the engine right away or do I get another car.
You should be able to find a used longblock (or a shortblock for that matter) dirt cheap. They were only used in almost everything for 10 years. S-10/S-15's, F-bodies, Fiero's, alot more I can't remember.
Check out the local junkyards there man. I think there is one over the bridge on 3rd, down by the turn off down Grand Ave. I cant rememember the name of the place off the top of my head. Also, I know that Cheyenne and Ft. Collins have really good junkyards. Hope that helps man...
You didnt blow your motor while you were racing in the Techer 500 did you?
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, Hi Flo Cat, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace.
-Roshambo
-Joe
Car: '89 Firebird
Engine: 7.0L
Just get an old crappy Civic or something. You're going to need another set of wheels when you do the swap. Might as well get it now and let the 'Bird sit. You'll be ahead money wise in the long run.
I don't actually remember how they are different, but it has something to do with the way they mount sideways and such... all I know is that a 3.4 motor isn't an option in a FWD car.
No I did not blow it up on the Tecker 500 Roshambo. It is not blown yet. Here is what has happend the piston rings have worn down to cause piston slap which caused the Rod to bend because the piston would not move evenly. The bent rod has caysed the crank to to whare out the barrings fast and the crank to bend. I can drive it but I don't want to be driving when it finnaly goes. just to let you know the fastest car on the Tecker 500 that is not "pushing juice" is a Blue Third Gen Trans AM.
<font face="Verdana, Arial" size="2">Originally posted by TeckerB316:
just to let you know the fastest car on the Tecker 500 that is not "pushing juice" is a Blue Third Gen Trans AM.</font>
Which classes are you taking anyways?
-Roshambo
I'm takeing the automotive core ASM and chassie Fab High Proformance engines. I'm in my second Phase Driveability and diagnostic (EMS 2) Ihav allredy passed EMS 1
</font>
</font>
So you figure out what to do with the Camaro yet?
-Roshambo
I have Jack Longrass and Tim Brocaw (EMS B) and we just finished OBD 1 and OBD 2 lecture and have half a day in the shop with it.
For the camaro I'm just going to put in what I can find and put it in at a guy in my classes house over dead week at the end of the month.
so did you go to teck?
sreZ28
Oct 22, 2015 08:21 AM
