Pacific Region Regional board for Pacific Third Gen owners.
Break Down!!!!
Old Aug 4, 2004 | 04:15 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Break Down!!!!
Thought I'd share my pain with everyone. It was gonna happen sooner or later. The RS has about 120,000 miles on it & I've never really had any serious problems with it. Well, the good news is, I got the suspension done & was taking it out for a test drive today. Bad news.......It died on me!!!!!! Luckily I died right around my house so I was able to call my younger brother to come & get me. I got stuck in the middle of the road & while waiting for my brother to come, some good hearted Mormons came to my aid. They helped me push the car out of the road & onto the side, out of the way. So I would just like to extend my thanks out to them! Got my brother to get my truck & pull me home. I'll update tomorrow on the diagnosis of the car. I hope it's not the fuel pump! I didn't want to mess with anything today after getting home. Just decided to let the car rest & tackle the problem tomorrow. Wish me luck!
Old Aug 4, 2004 | 07:22 AM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
Ouch sounds painful, I hope you get the RS back up and running soon, and yes, let's hope its something minor, and not the fuel pump.
Old Aug 4, 2004 | 12:12 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Goodness. I've only got 18,000 to go before I get to where your at. Hope my engine lasts until I rebuild it. I always thought the LO3 was built for reliability, though. Let us know, and if it is the motor, sounds like a really good excuse for a rebuild/swap!
Old Aug 4, 2004 | 06:36 PM
3rdGenBlackBird's Avatar
Re: Break Down!!!!
But what we all really want to know is, how does she handle now? Hehe, just kiddin'. At least you were close to home and have reliable help.
Keep us updated man.
Old Aug 4, 2004 | 08:25 PM
Car: 89 RS
Re: Re: Break Down!!!!
lol! Handles like a dream Scott!! Got some sliding action going with the wet roads & just started having some fun then......Brrrrr..........DEAD! lol! I'm leaning toward an ignition problem. Either some burnt wires caused by the headers causing an amazing arc light show, or a failing ignition module. Got it running today, missing like a mother, & rich as hell. So I know fuel isn't the problem. Gonna check it out tomorrow, got too many things to do today. But yeah, it handles awesome
Old Aug 5, 2004 | 03:56 PM
Car: 89 RS
Quick update. It wasn't the ignition module. Gonna go check the condition of the wires & plugs today.
Old Aug 5, 2004 | 09:14 PM
Check your flux capacitor. That thing keeps goin' out on me!
Do ya' have fuel pressure?
Old Aug 5, 2004 | 09:57 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Hahahaha, never could get mine workin right, so damn you.
Old Aug 6, 2004 | 12:59 AM
Car: 89 RS
Yeah I have pressure. I think it was around 10 to 15. Would a dying fuel pump cause a stumbling, missing, & smoking exhaust at idle???
P.S. my flux capacitor is brand new along with Mr. Fusion I'm starting to take this problem as a sign for me to swap in a long overdue new motor I've been trying to put together.
Old Aug 6, 2004 | 05:03 PM
Mr. Fusion... hahah.
I don't think a dying pump would cause those problems unless it's pushing a grossly wrong pressure. I didn't see the part of your previous post about running rich and all. What is the normal range for TBI? Around 1.5 ~ 2x carbs?
What color is the smoke? You said your ignition all checked out good, right? Have you checked for vacuum leaks?
I'm probably going to have all kinds of problems with my truck once I finally get around to putting it back together. I've been spending my nights after work taking things apart and cleaning them. But I'm getting really lazy about labeling everything, so there will be lots of trial and error troubleshooting to do....
Old Aug 7, 2004 | 08:21 AM
Car: 89 RS
Gonna change out my O2 sensor later on today. Found out that I'm throwing a code 44. Lean exhaust indication. I'm suspecting that my O2 sensor has gone bad. In theory I believe that the ECM would add more fuel from the bad sensor thinking that its lean.......Or so I hope! It would explain the rich smell of gas that I'm getting & the smoking exhaust while I have the car sort of running. Oh well, wish me luck!
Old Aug 8, 2004 | 08:32 AM
Car: 89 RS
Well, I think I might of found the problem. To make a long story short, I found out that 2 of my spark plugs were only finger tight & one was actually spinning freely! I think I might have compression lost in those 2 cylinders & thus causing me to not fire correctly......I hope! Go check out my other thread for more details
https://www.thirdgen.org/techbb2/sho...hreadid=253887
Old Aug 9, 2004 | 04:12 AM
CrazyHawaiian's Avatar
Car: too many ...
Well if you need any L03 parts you know who to call. Glad to hear you found out what it was. I think the car is telling you it wants the 350!! hehehe
Old Aug 9, 2004 | 07:39 AM
Car: 89 RS
That's exactly what my wife told me......Might be a sign!
Old Sep 9, 2004 | 12:01 AM
Car: 89 RS
The car is running!!!!!!!!!!!!
Just wanted to let you guys know that I got the car running today. Turned out to be a leaky injector. I had my suspicions on that when I noticed that one injector was spraying out fuel when you just turn the key to on. (fuel pump energizes for a few seconds, & the leaky injector squirts it right out) So that would explain why I was running sooooo rich when I did get it started. I would just like to say thanks again to Shawn for the spare Throttle Body with the injectors. I couldn't of done it without you man!
And just to add, never underestimate your g/f or wife when she says what the problem is with the car. My wife kept telling me that it was a fuel problem & I kept ignoring her & said it was something else. And look what happens, it turns out to be a fuel problem You gotta love how that turned out
Old Sep 9, 2004 | 02:56 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Hey, cool. I'm learning that too, slow as it is...
Old Sep 9, 2004 | 01:43 PM
Smart wife! Glad you got her running again man! Now you can enjoy your new suspension after all that work.
So what's next? 350 time?
Old Sep 9, 2004 | 02:14 PM
Car: 89 RS
Tell me about it. I haven't heard the end of it from her yet
Your suspicions on a 350 are right. I just wanted to get the car running so I could fix the scratches on the driver side door & get my ghost flames done
I have some vortec heads that I scored for really cheap & am gonna get the machine work done on them soon. I'm getting a short block from Scoggin Dickey Parts Center soon. They have the best rates on shipping that I've found. Valve train is gonna be all Comp Cams stuff.(Getting it through a friend) Laterz.
Anthony
Old Sep 9, 2004 | 10:21 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Tell me about it. I haven't heard the end of it from her yet:doh:
Your suspicions on a 350 are right. I just wanted to get the car running so I could fix the scratches on the driver side door & get my ghost flames done :D
I have some vortec heads that I scored for really cheap & am gonna get the machine work done on them soon. I'm getting a short block from Scoggin Dickey Parts Center soon. They have the best rates on shipping that I've found. Drive train is gonna be all Comp Cams stuff.(Getting it through a friend) Laterz.
Anthony
How much is it costing to bring in the short block? Is it by freight forwarding?
Old Sep 30, 2004 | 04:37 AM
Car: 89 RS
Bad news again. This happened a little after I got the RS running but I just never posted my pain yet. The car is running all messed up again. It's actually kinda strange & I'm stumped right now. I start the car up & it fires right up & idles fine for about 20-30 seconds. Then right after that it starts to have like a popping sound, almost like light backfires. Just moving the car in & out of the driveway it does that popping sound even more & it sounds of backfire more too. I'm not pulling any codes also so I'm not sure what the problem could be. Anyone have thoughts on this. Clogged fuel filter? Sensor failures even without pulling codes? Spark plug wires arcing?(but wouldn't it idle funny from the beginning right after fireup?) Timing off? Hope I solve this soon.
Or maybe that carbed 350 might find a new home in the engine bay sooner than I thought lol!
Old Oct 1, 2004 | 06:36 AM
Car: too many ...
I thought about it after you told me. My guess would be something fuel related since thats where the last problem was. But might also want to check the connection on all the plugs, or maybe even pull the plugs to check em out. How old are the wires? The weird thing is that it only happens after the car warms up ...
Old Oct 1, 2004 | 08:09 AM
Car: 89 RS
Yeah, I'm still leaning toward a fuel related problem. It's the little problems like these that really irritate me though. Oh well, since this isn't a top priority for me right now, I'll let you guys know how things go when I get to it
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
