Pacific Region Regional board for Pacific Third Gen owners.
HELP possible trans problems
Old Apr 22, 2006 | 08:57 AM
808RS's Avatar
Car: 91 RS
Engine: 305TBI
hi i was wondering if someone could help me i have a 700R4 with about 135xxx miles on it also go a shift kit inside. when i gas it it feels like theres a lag going into first gear and its not as snappy as it used to be. also when i start it up it surges a lot from like 500 rpms-1500 rpms. anybody have any idea of what could be wrong? could the trans be going on me?
Old Apr 22, 2006 | 05:15 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
It sounds more like you need a tuneup, unless the engine is revving and the car isn't moving...
Old Apr 22, 2006 | 05:59 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
torque converter could be on its way out.
Old Apr 23, 2006 | 12:41 AM
3rdGenBlackBird's Avatar
What's the condition of the fluid?
Scott
Old Apr 24, 2006 | 07:01 AM
CrazyHawaiian's Avatar
Car: too many ...
If its surging at idle then I would suspect something is up with the engine. When this happens at low RPM's are you in gear or does it also happen when you're in park/neutral? No SES light right?
Old Apr 27, 2006 | 01:28 AM
Rainman's Avatar
Car: 1989 Firebird Formula
Transmission: WC T-5
Axle/Gears: Moser 12 bolt, 3.73 gears
Have you tried adjusting your tv cable??
Old Jun 17, 2006 | 01:48 AM
Duck's Avatar
Engine: 5.7
808RS -- what's going on with your trans?
Old Sep 7, 2006 | 10:59 AM
invrluz383lt1's Avatar
its torque converter locking ,on and off g.m found out about this problem and released a new eprom for all cams/birds that elimanates this problem ,its not shifting like it shoud because the converter is not operating properely .so go to gm give them your vin and get the chip it elimanates the surging ,lock up problem and gear hunting ,i know because im a service tech at a chevy dealer ,and the chip is cheap about 50 bucks
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
