Pacific Region Regional board for Pacific Third Gen owners.
OBD Code Reader ??
Old Jul 6, 2006 | 03:35 AM
xklipze's Avatar
OBD Code Reader ??
anyone in oahu have a OBD Code Reader, they would be willing to figure out why my light wont go off.. i would appriciate it alot....
my car has the most ridiculous problems all of a sudden, and im pretty broke... i will travel anywhere on the island..
figured i'd ask
Mahalo!!!
Old Jul 6, 2006 | 06:59 AM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Easiest way to figure out your problem is to get a paper clip and short terminals A & B on the diagnostic connector in the car under the steering wheel over to the right. turn the ignition in the on position but dont start it, the engine light will flash codes, long flashes indicate increments of 10 and short flashes increments of one. Next get a Chilton service manual and look up the code. If I lived near you I would lend you my Auto xray code scanner...
hope this helps
Old Jul 6, 2006 | 09:33 AM
3rdGenBlackBird's Avatar
I think Checker will read them for you. Might even clear them too if they can.
Old Jul 6, 2006 | 09:07 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
I'd do what Crusher said. Ignore code 12 as you'll get this since the engine isn't running. Give us a little more info on your TG so we can help you better!!!
Old Jul 7, 2006 | 01:44 AM
xklipze's Avatar
the car is having a really wierd problem.. and i dont know where to begin trying to figure this one out.. im usually good at this stuff too
this is a link to the problem im having, i have tried to describe the problem as best as i can.
https://www.thirdgen.org/forums/tech...ml#post2968613
Old Jul 9, 2006 | 09:58 PM
homerunchamp's Avatar
Car: 2007 Dodge Charger R/T
Engine: 5.7L HEMI
You get this figured out yet? Did you swap the EGR or no?
Old Jul 10, 2006 | 04:50 PM
xklipze's Avatar
yes, i figured out how to read the codes off the computer......
I used the "paperclip" method...
If anyone wants to learn how to read the codes off the copmputer, just shoot me a Email i will answer any questions.
The bigger problem i am having now, is still debatable.. im almost at a loss i just dont know what the problem could be.
Old Jul 10, 2006 | 09:00 PM
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
This seems to be the latest and greatest...
https://www.thirdgen.org/forums/tech...-solenoid.html
...after finding the crappy coil wire, I'd suggest you check everything else down stream from there, too...coil wire, cap, rotor, 8 plug wires and spark plugs.
Old Jul 14, 2006 | 12:59 AM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
dude i work at advance auto ..... just go there they do free obd testingand if they say they cant just say you worked at another one and know that they can.....say salem in nj but they can doo it trust me
Old Jul 14, 2006 | 01:06 AM
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
That's gonna be a little hard to do considering we don't have any of dem stores here in Hawaii!!! ...but yanno Checkers may offer the same service. Then again...it's a moot point...he already pulled the codes with the paper clip!
Old Jul 14, 2006 | 03:55 AM
xklipze's Avatar
yeah that paper clip trick worked nicely...
so the car has like 4 total problems.. but then at other times everything is peachy... makes no sense at all..
I think the ECM is just acting stupid.. because everything is just crazy...
Today i did a 3 point turn at like 3 mph.. and the whole car died.. no poweer at all .. anywhere..
maybe the battery isnt connected as tight as possible..
but thats not the case.. its so mind boggling..
so i have a ECM problem i think, a VGR valve problem or solenoid.. a crappy vaccum hose problem... a ignition switch problem, my window motor is gone, and my coil sucks bad too... lol.. go figure..
To rule out my battery and alternator(for my power problem, (random power loss at total random, then recovery (stereo))) i am going to take my battery and alternator into checkers auto parts, and have them test both.. Pretty Nuts huh ? and im broke no money.. and hav like 50% of the tools i need lol.. my life sucks..
After work tommorow, i will have the cash to buy a new coil, new spark plug wires, and spark plugs, cap/rotor
Thats everything for the ignition to be rules out, correct ?
I should grab a new ignition switch too..
Old Jul 14, 2006 | 11:27 AM
85T/A's Avatar
well the reason i told him to go to an advance was because we print the codes out on paper so that you could read them instead of counting flashes
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
