Parts Wanted 2006 Looking for something in particular? Ask here.
Computer TPI 350
Old Aug 12, 2005 | 05:01 PM
88cam's Avatar
Computer TPI 350
Doin an engine swap and I need a computer from a 350 tpi with an auto trans.
Old Aug 12, 2005 | 07:01 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Computer
If you mean the silver box under the dash on the passanger side I got one off a 305 TPI.... I think its what your looking for. Not positive its the same tho.
Old Aug 13, 2005 | 04:48 AM
88cam's Avatar
I have a 305 comp but I need a 350 comp. They have diff data. but thanks I might have one now thanks to Intruder
Old Aug 13, 2005 | 08:29 AM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
The 305TPI and 350TPI use the '165 ECM for MAF or the '730 ECM for SD.
The chip itself is what is different between the 305TPI and the 350TPI.
Old Aug 14, 2005 | 03:19 AM
88cam's Avatar
oh woah that brings up next question. if I do get a 350 comp does that mean I'll be operating under SD and have to get a new wiring harness or will I still be working with MAF? I Knew that one chip was different but the SD and Maf thing is a new thing to me. thanks for tellin me about that.
Old Aug 14, 2005 | 03:23 AM
88cam's Avatar
Actually gm didn't use Speed density till the 90s I thought and they had Maf 350s before that so forget what I just said in the last post.
Old Aug 14, 2005 | 02:35 PM
1trick67's Avatar
Car: 88 gta 67 camaro
Engine: 5.7 350
Transmission: 700r4 with shift kit muncie 4 sp
i have a 350 tpi comp i will sell for 80.00 plus shipping email me at leonardclok@comcast.net
Old Aug 14, 2005 | 03:02 PM
88cam's Avatar
email sent
Old Aug 15, 2005 | 07:18 AM
TKO500's Avatar
85 - 89 Used the '165 ECM (MAF)
90 - 92 Used the '730 ECM (SD)
I have one of each available. The ECM's are $50 + shipping.
PM if you are interested.
Old Aug 15, 2005 | 01:34 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Not quite true.
85 used the 870 ecm
86-89 used the 165
88cam, you need to choose the ecm you need, depending on your harness. All ecms were the same for 305s and 350s within the same year, what changed was the computer chip.
Old Aug 16, 2005 | 07:34 AM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
complete 88 iroc drivetrain
https://www.thirdgen.org/techbb2/sho...hreadid=315516
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
bamaboy0323
Aug 15, 2015 07:20 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
