Parts Wanted 2006 Looking for something in particular? Ask here.
HEADS!!!
Old Apr 1, 2006 | 08:19 AM
theopsmanager's Avatar
HEADS!!!
I need a good set of performance heads bad. If any one has any to sell or trade pm me.
thanks
Old Apr 1, 2006 | 10:26 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I have a set of nice vortecs 9906 cast number. have pics if interested. Looking in the 300$ range with valve springs etc
Old Apr 1, 2006 | 12:52 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
HEADS
For what engine. I have a set of heads #601 53cc for a 305 that will raise the compression since it has lower cc than the standard 305 heads. Usually they come with 58cc heads. Let me know if this is what you are looking for. I've also been told that installing 1.94 intake valves and mild porting, these heads will flow better than the vortec heads.
Old Apr 1, 2006 | 01:09 PM
BROKE400's Avatar
have a set of world products 042770 76cc with manly screw in studs and guid plates only have 5k on them 350 plus ship. they are 87 up center bolt also give you a set of crome valve covers.
Old Apr 1, 2006 | 02:04 PM
They will be going on a 350 punched 40 with flat top pistons, a comp cam magnum 305H cam, long tube headers, performer RPM airgap intake with a 750 double pumper. I had a set of Sportsman II heads that performed great. They were 64cc with 2.02 / 1.60 valves. I would like to go back with a similar setup. How do the Vortec heads flow compared to aftermarket heads such as sportsman II.
Old Apr 1, 2006 | 03:10 PM
Car: 2002 SS
Engine: Ls1
My vortec 906 head specs= are all right here... Look at all the previous test cfm before they ported them, these that I have are untouched btw. Lol my heads are untouched and your talken about porting etc, vortec heads=one of the best budget heads out of the box in the market.
vortec info = Vortec CS GM head
sportsman II info = http://www.worldcastings.com/tech/SportsmanIITech.pdf
sportsman II
at .500" lift intake = 240 cfm/ exhaust = 164 cfm
Vortecs
at .500" lift intake = 228.8 cfm / exhaust = 147.6 cfm
just the facts...
Old Apr 1, 2006 | 03:39 PM
Will I need to purchase a new intake if I use the vortecs?
Old Apr 1, 2006 | 04:05 PM
Car: 2002 SS
Engine: Ls1
yes, they actually make an rpm air-gap intake for the vortec heads. Sorry I dont have that also. But it's what I was gunna go with.
Old Apr 1, 2006 | 04:22 PM
Would I see very much difference in performance using the vortecs over the sportsman II and are they 64cc heads?
Old Apr 20, 2006 | 04:21 PM
88BlackZ-51's Avatar
I have a brand NEW set of Trickflow's. 195cc/62cc. I have had them flow tested, 260cfm at .550 lift.
Old Apr 20, 2006 | 06:49 PM
Thanks but I will need either a 2.02 /1.08 or 2.05 / 1.08 valve setup.
Old Apr 20, 2006 | 09:04 PM
o.k. my valves are 2.02's.
Old Apr 21, 2006 | 12:53 AM
How much?
Old Apr 21, 2006 | 09:26 AM
$1000 obo.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
