Twin Eatons - intercoolers mounted
Old Dec 16, 2002 | 09:16 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
While waiting for the second Eaton and materials to arrive to mount it, I have been busy getting the intercoolers and ducting built. I lowered the radiator 1.5 inches and layed it back 2 inches. The blow off valve mounts to the underside of the duct to the TB. Need to make up a new piece to cap off the top of the radiator to the core support. No biggie. more pics to follow. cheers, Bob
Old Dec 17, 2002 | 12:35 AM
rooster433's Avatar
very very nice,
looks like I might have to break out my welder!
This should be a nice project. I think 1 eaton would have sufficed on your 305. There is a company called allen superchargers that uses M90's on all of there kits. (crown vic, cobra,GT, F-150 etc)
I'm not complaining about using 2 though, should be REAL quick if it turns out like www.toohighpsi.com
Old Dec 17, 2002 | 07:09 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
The 305 is just the mule... I have a 88 350 roller short block waiting to be stroked and built. Heres a side shot of the engine at present.
Old Dec 17, 2002 | 07:12 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
front.
Old Dec 17, 2002 | 09:38 AM
bhaas's Avatar
Looks sweet. Have you driven it yet? Keep up the good work.
Brad...
Old Dec 17, 2002 | 10:03 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
That, my friend, looks like it will be a killer setup. Keep it up and us informed!
Old Dec 17, 2002 | 08:45 PM
Dan W's Avatar
Is a compressor chart available for an Eaton?
Old Dec 17, 2002 | 09:10 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
http://www.automotive.eaton.com/prod...trols/M90.html
Old Dec 19, 2002 | 11:29 PM
rooster433's Avatar
Curious,
The stock M90's have a vaccuum actuated valve on the side, are you using this? What is it for?
What regulates how much boost is comeing to the motor at a idle or cruse?
Old Dec 20, 2002 | 07:21 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Originally posted by rooster433
Curious,
The early M90's (89-92?) don't have the intergral blow off valves. The later models do. I'm using a 1g DSM blow off valve between the intercoolers and TB. cheers, Bob
Old Dec 20, 2002 | 07:33 AM
Guido's Avatar
Car: 2000 Trans Am
Lookin good Bob! Cant wait to see the other one mounted on the car.
Keep us posted!
Old Dec 21, 2002 | 12:02 AM
rooster433's Avatar
Correct me if I'm wrong please, my SC vocab is a little weak.
I thought all blowers needed a wastegate more than anthing else. What I mean by this is something to cycle pressure off the intake side of the motor when high vaccum, cruise/idle
If your at an idle for instance, what keeps boost from climbing up?
Old Dec 21, 2002 | 01:11 AM
83 Crossfire TA's Avatar
Hey Saturn5, I keep thinking this and forget to ask... What is your manifold coated with? I love the look...
Old Dec 21, 2002 | 09:23 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Late 90's Ford Autumn Orange off the Explorers. Basecoat/clearcoat. I sanded the intake and runners for shine, cleaned and painted. Didn't use any primer to let the aluminum shine thru, the basecoat is translusent.
Old Dec 21, 2002 | 09:34 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
I'm adding a blow off valve between the blowers and the tb. under vacuum it will bleed off the boost. Since I'm running a 749 (speed density) this loss of air won't matter. cheers, Bob
Old Dec 21, 2002 | 10:26 AM
87transam5.7tpi's Avatar
very nice. looks like it will be a VERY fun ride.
Old Dec 21, 2002 | 10:34 AM
Very cool on the paint. How is it holding up in the engine bay? I've long considered doing something similar but haven't gotten off my butt to do it. I was almost thinking that you somehow managed to annodize the whole thing (you'd need a big tank and power supply to do that)
Old Dec 21, 2002 | 10:40 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Holdiing up fine (Sikkens Ureathane). Have a few scratches from tools I need to touch up, but other than that no problems.
Old Dec 21, 2002 | 06:05 PM
MdFormula350's Avatar
looking great!
86Firebird86
Dec 26, 2015 07:21 AM
dbrochard
Oct 3, 2015 12:43 PM
customblackbird
Oct 1, 2015 04:30 PM
ynk1121
Sep 12, 2015 12:27 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
