front mount intercooler people.....
Old Apr 14, 2006 | 02:57 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
how far is your IC from the radiator? and does it lay back like the radiator does??
Old Apr 14, 2006 | 03:44 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
MInes far enough away to fit you fist between the IC and radiator. Its kind of angled toward the motor but only slightly. Its definetly better than the scoop that ATI gives to block airflow to the radiator.
Old Apr 15, 2006 | 08:30 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
here's a pic of my old one! sorry for the blurring view that's flush to the radiator....
The new one will be mounted the same way only with shorter piping since it has the turndowns already.......
Old Apr 15, 2006 | 08:31 AM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
pic of new one
Old Apr 15, 2006 | 08:35 AM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
here
Old Apr 15, 2006 | 09:41 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I've got mine in front of the radiator, tipped forward. The bottom edge is about an inch or two fwd, resting on the bottom of the frame opening, while the top has a good 8" clearance.
Skulte Performance Designs Photo Gallery - Copyright 2005 :: Z28tt
Old Apr 15, 2006 | 10:21 AM
Car: '91 Camaro RS
nice work guys......
askulte, so you have what? one airdam forcing air up through the IC then the radiator???
my biggest concern is getting enough air to both
Old Apr 15, 2006 | 12:51 PM
Car: '91 Camaro RS
also.....what did you attach the bottom supports for the front bumper cover to after getting rid of the stock support? or did you just not worry about those
Old Apr 15, 2006 | 01:16 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Just a nice open front-shot through the front valence. Too much air makes it through there, and makes the front of the car wander at high speeds. I no longer have a radiator lower air dam, either. On the list of things to do is modifying the hood to extract that air, possibly tilting the rad forward with the IC.
The lower valence supports are just along for the ride, but could be dzus'd to the radiator/IC shroud.
Old Apr 15, 2006 | 04:20 PM
Car: '91 Camaro RS
thanks man......i basically duplicated you're front bumper support this afternoon already and built a trick little set of intercooler mounts......i just painted the pieces and hopefully i'll assemble them and partiall put the nose back together tomorrow.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
