K&N FIPK for a 3.1L
Old Apr 26, 2002 | 04:36 PM
1991cv's Avatar
Car: 1991 Camaro RS
Engine: V6
K&N FIPK for a 3.1L
I know K&N doesn't make a Fuel Injection Performance Kit for my car but I was wondering If they had one that I could adapt to fit my engine. I have a 1991 Camaro RS with a 3.1L 60 degree V6. I sure would appreciate someone's help.
Old Apr 27, 2002 | 05:24 AM
89camaroRSV6's Avatar
try posting this in the V6 forums area...guys there have a lot more of custom CAI's and ram airs there using universal K&Ns
Old Apr 27, 2002 | 07:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
what is wrong with the two 33-2008's that the V8 cars are running being used on your v6?
Old Apr 28, 2002 | 10:15 PM
he doesnt have the dual snorkel...
90+ camaros went with teh coffee can single side intake ....the only way to make that better is to go for a conical air filter or cut the bottom out
Old Apr 29, 2002 | 10:06 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
coffee can on the intake? who says GM wasnt ahead of thier time? they just accidentally put it on the wrong end of the car (just ask any *****, or look under thier rear bumper) does the TB on this V6 still face froward so a dual snorkel lid and filters could be used?
Old Apr 29, 2002 | 12:42 PM
lol b4ctom...
"they accidentally put it..."\
man im still laughing at this one
yeah the TB is teh same ..only thing is that the MAF went out
90 they switched from MAF to speed density...
this is where the GM engineers took the dual snorkel out and put the single side intake in...
i tried lookin for a picture ..but couldnt find one...ill see if i can post one later(i cant post mine as i have an 89 with the dual snorkel...)
yeah the 90's stock are more restrictive than a 89 dual snorkel..
some ppl do the swap...but it takes time..since u need the whole thing including the airbox and u need a plastic pipe where the MAF was in the dual...ohh yeah and Relocate the IAT..
better than all this is to do a custom conical filter in the place where the intake is on the side on the 91 ...
Old Apr 30, 2002 | 01:51 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
YOu should just make a custom air intake kit for the V-6 using the dual snorkel. You can easily find the snorkels in a local salvage yard for a couple of bucks. The air cleaner should still mount on top of the tb just fine. All the screws to mount the snorkel should still be there, but you'll have to move the mass air flow sensor to on the snorkel, which could be expensive if you have to buy a new one.
Old May 3, 2002 | 10:40 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
some of the V6 airbox lids even have the IAT sensor mounted on to one side, I think yours is in the intake ducting tube, or is it in the intake (after the throttle body) plenum? dont forget to get the whole air box. and then cut out the silencers/baffles directly under the air filters. no water splashes up that high so there is no water to worry about, unless you have an inboard/outboard F-body.
jhawkeye
May 25, 2022 06:33 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
WIzmo
Aug 30, 2015 02:30 PM
