Dyno run on nitrous- Why so different?
Old Apr 30, 2002 | 09:16 AM
Brandog87GTA's Avatar
My buddy's LS1 was running a 100 shot and he only got a 70 RWHP gain and like 125 RWTQ gain. I on the other hand almost got 200 RWTQ gain and 150 RWHP gain from the 150 shot! Does my cam and open exhaust make that much of a difference in how much nitrous power I make?
Old Apr 30, 2002 | 09:58 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Did you really make more NA real wheel HP than torque??? What do you shift at? It all depends on jetting, bottle pressure, pumping losses, wet or dry syatem, there are too many variables.
Old Apr 30, 2002 | 11:07 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
You didn't say if you both were running the same brand kit, the same style system (wet or dry), and if both were running the correct bottle pressure and fuel pressure. Too many variables / not enough information.
Old May 3, 2002 | 10:47 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the first numbers sound like NOS dry #'s and the second set sound like NX or TNT wet #'s
Old May 7, 2002 | 09:07 AM
we both are running NOS kits, his is dry mine is wet. I have no pressure gauge but he has a bottle heater and a gauge. My bottle was warm during my run and I am sure his was too.
Oh by the way, I entered in a 2 instead of a three, its suppose to be 354 RWTQ
Old May 7, 2002 | 09:52 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Originally posted by Brandog87GTA
we both are running NOS kits, his is dry mine is wet. . .
so i was pretty close, I do alot of dynoing here. if you check the jet sizes between the two kits like for the same size shot (I saw that he used a 100 and you the 150) like your 150 and his 150 and compare the orafice size between the two you will see that the "dry" shot size orafice is very "optimistic" usually no where near the .069-.073 size needed to deliver the approximate 6 lbs per minute required for 150 hp at 900-1100 psi. this is just the nature of manufacturers and thier figures on ratings. the NX kits are all "wet" and at $489 are a bargain for the LS1, LT1, or TPI cars. they deliver as advertised within a plus or minus of just a couple of HP.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
1984HO
Mar 19, 2021 11:59 AM
Fast355
Dec 2, 2016 06:33 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
