nitro install simple ?
Old Jun 1, 2002 | 07:27 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
i'm helping my brother install his nitro systerm and need to know what sealant to use on the fittings
Old Jun 2, 2002 | 03:42 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Nitro? I hope you mean Nitrous Oxide. Im not at all experience with N2O (Nitrous Oxide) but I THOUGHT that you werent supposed to use thread sealant...
Somebody chime in... Am I correct?
Old Jun 2, 2002 | 09:41 PM
92superram's Avatar
I'm pretty sure teflon tape will work fine.
Old Jun 3, 2002 | 08:12 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Thread sealant isn't reccommended.. but if you need to use something, use either liquid teflon/teflon paste, or the supplied red thread locker-type liquid. Do not use teflon tape. Do not use thread locker.
Old Jun 3, 2002 | 08:21 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
thanks, i appreciate it
Old Jun 3, 2002 | 09:37 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
use sealant only on the "pipe" sides of the fittings not on the self sealing "flare" ends of the fitting. not like this Bozo did:
Old Jun 3, 2002 | 11:16 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
B4Ctom1... lemme guess... he leaned it out and popped it huh?
Old Jun 3, 2002 | 08:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
luckily the install was so shoddy, that the selenoids would not fire. we do a pro install of a nitrous system including dyno for $300 to $360 depending on access to the throttle and trunk bottom. he said that was too much and said another shop woud do it for $100, so he took it there, then brought it to me for $400 worth of after repair. I had to properly install the nozzle in the tube (so the hood would quit breaking it) and fill the old hole (ugly repair hidden by cool NX sticker), fix all the fuel leaks, put in line fuses (and repair a burnt fusable link), rewire, relocate the throttle switch so that it would quit holding the throttle wide open, and rethread plenty of it. just look at these before and afters:
NORTz89
May 20, 2020 03:51 PM
redmaroz
Apr 25, 2017 07:14 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
nuggie
Aug 25, 2015 01:27 PM
Fronzizzle
Aug 17, 2015 02:52 PM
