220cc heads
Old Aug 13, 2002 | 10:40 PM
pronger44's Avatar
220cc heads
are aluminum AFR 220cc heads too much for a 350 even if it's supercharged?
Old Aug 13, 2002 | 11:17 PM
BlownBird's Avatar
Contrary to popular belief, no head is too much for a supercharged motor. The more volume you can push in, the more power you will make.
Old Aug 14, 2002 | 01:12 AM
89ProchargedROC's Avatar
True, but you cant put in a baby cam......so that has to be considered also
Old Aug 14, 2002 | 07:58 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Actually, that is not entirely true. For a roots (or positive displacement supercharger), yes - you force air in. For a vortech/paxton/powerdyne/ATI - no, it needs to spin higher to give boost (compressor type supercharger and turbos).
I'm not even mentioning the fact that if a blower is too small for a motor (a 144 on a 500hp 383 for example), it may actually be hurting performance.
The rule of thumb should be (regardless of supercharging/turbocharging) for picking heads - pick the smallest cc head with the highest flow in the range you are operating (.700' lift flow #'s don't matter if you are running a .500" cam). For example, a 180cc head that flows 250cfm is a better choice than a 210cc head that also flows 250cfm. The smaller head will produce more bottom end TQ with the same hp, which makes faster acceleration.
You should check exh/int flow % on the heads you wanna buy. If it is above 80% then you can run a single pattern (or dual); below 80%, run a dual pattern (supercharged/turbo/N2O).
Old Aug 16, 2002 | 12:41 AM
pronger44's Avatar
so with a super charger it's all about the cfm's not cc's?
Old Aug 16, 2002 | 01:59 PM
paul_huryk's Avatar
pronger,
The answer is yes (in most cases), but that also applies to NA motors too. The exception is when you need to run big ports in order to get to a certain RPM level (using a super Victor for 8000rpm), which is typically rare on a streetable motor.
Maybe I went off in a tangent with my last reply, but the idea is to get a nice flat powerband, which includes a good low-mid range TQ presence. You can't get good low end on a 350 with 235cc heads, but you can with 1800cc ones - and you probably never be able to use all the flow the big heads have on a sub 8000rpm motor.
I would say go for the 190cc heads and a supercharger (if you want it). AFR has dyno tests of some motor combos on their web site - take a look.
Old Aug 16, 2002 | 04:10 PM
Guido's Avatar
Car: 2000 Trans Am
Good thoughts there fellas.
The smaller the port, the higher the air velocity; hence your low end torque production.
Old Aug 16, 2002 | 04:23 PM
BlownBird's Avatar
Sorry for the bad info guys... I was thinking on the lines of max power. Guess i better build a larger motor for my heads
Old Aug 17, 2002 | 12:48 AM
No you dont.....your motor is setup very well
Old Aug 18, 2002 | 03:14 PM
87_TA's Avatar
When building a blower motor the larger intake runners the more volume the charger has to fill there fore losing boost and velocity.
You dont need super high flowing intakes because you are forcing your air in,the exhaust side of a head is the area that needs to be concentrated on with a blown motor to eliminate self EGR,ing.
Old Aug 18, 2002 | 04:39 PM
That is true and it isn't........you dont NEED a better flowing intake
BUT
it will allow you to make the same horsepower with LESS pressure (boost) because it flows more air
--Also, on a side note.....if you are worried about losing velocity in the heads with a blown car you are one sandwich short of a picnic
Old Aug 18, 2002 | 04:55 PM
87_TA's Avatar
Better flowing,yes..
bigger,no..
read the post,and i will keep my sandwich.
Old Aug 18, 2002 | 11:46 PM
bigger,no..
huh?
chew a little more and respond again please
Old Aug 24, 2002 | 01:47 AM
logikal6785's Avatar
Originally posted by 89ProchargedROC
huh?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
