nos=torque
Old Aug 14, 2002 | 09:36 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
nos=torque
i have a question for u guys....when u install a nitrous system your obviously going to get the 100 or 125 hp that is advertised...but how much torque will be added??
Old Aug 15, 2002 | 01:48 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
On a typical 100hp shot you should see around a 100hp gain,but torque will increse more than hp.Torque increases more than the HP rating of the jets.
Old Aug 21, 2002 | 03:04 PM
jimmbo's Avatar
just remember
build for torque and horsepower will take care of itself
also when you hit the nitrous button or activate the n20 however you have it set up that is your torque peak
its all downhill from there!!!
Old Aug 21, 2002 | 03:09 PM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
Well the HP gain is going to DEPEND on the system you use..
NX rates their kits at the rear wheels...
NOS rates their kits @ the flywheel..
Torque is a HUGE factor w/ nitrous... you will get gobs of it..
Old Aug 22, 2002 | 05:50 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
so then wouldnt the nx kit be better then?...tpi makes pretty good torque as it is so i guess im good....
Old Aug 22, 2002 | 06:47 PM
1982chevycamaroz28's Avatar
yes but the TPI runs out of pwoer around 4500. am i right or no?
Old Aug 22, 2002 | 08:42 PM
JR305's Avatar
Since NX rates their kits at rwhp would this mean that they are much harder on the engine? So you could run a 120hp shot on a NOS kit and it would be the same as a 100 shot on the NX kit?
Also does anyone know what the max hp recommendation on a 305 for the NX kit?
Old Aug 22, 2002 | 09:56 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
just to add my $.02 the NOS kit rates at the rear wheels. It was shown on my recent Dyno run.
Old Aug 23, 2002 | 10:38 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I talked to an NX Rep at a show at VMP and he said that 75-100 shot is okay for a stock motor that is in good running order.
Anymore than that and you will need to upgrade fuel system and possibly upgrade the motors internals.
About the Torque question,
A buddy of mine with a 98 Z28, MM stage 2 heads, cam, headers, exhaust and 3600 stall dynoed 408RWHP and 480RWTQ, N/A. On the 150 shot with no bottle pressure he got 480RWHP and 623RWTQ.
His car is a monster, looks bone stock with SLP dual on the left exhaust making it look like a V6 Camaro till you hear the motor.
Old Aug 23, 2002 | 11:07 AM
jimmbo's Avatar
"NO BOTTLE PRESSURE"
i think you may want to re phrase this given thats its a pressure orientated system i find it highly unlikey that this car made
what about seventy or so more hp and about 150 ft lbs of torque
by adding nothing but fuel!
just a thought!
jimbo
Old Aug 23, 2002 | 11:14 AM
Zepher's Avatar
Ok, I should re-phrase that to "Not enough Bottle Pressure".
He had around 800-900psi instead of the normal 1100-1200.
He doesn't have a bottle heater.
Old Aug 23, 2002 | 11:52 AM
logikal6785's Avatar
how long is ur LT4 going to last with a 200HP shot ? =/
Old Aug 23, 2002 | 12:05 PM
Zepher's Avatar
Don't know until I try.
Seriously, I want to go forged internals before I give it the "big" shot. I'll do a 2 stage setup with what I have now if I don't get the forged parts right away.
50 shot primary and 100 shot secondary.
Old Aug 25, 2002 | 04:44 AM
sounds safe. or reasonably so.
Old Aug 26, 2002 | 04:49 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
yea the tpi falls on its face above 4500 but thats were the happy gas comes into play id hit the juice after i shift into 2nd and let off the gas at 5200 so the last few hundred rpms can clean out the cylinders so i dont load up them up with the spray
Old Aug 30, 2002 | 01:40 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
just a note, most people prolly know this but some dont,
nos = torque is good, but I think more accuratelly: nos = Cylinder pressure.
remember that nitrous is infamous for its crazy-high cylinder pressures, especially at lower RPMS and especially with "computer cams" (wide LCA cams) if you have a stock head-gasket its easy to blow it hitting the N20 too early or not retarding your timing enough... you can see 250/300 PSI if your not carefull enough....
Old Aug 30, 2002 | 11:46 AM
jimmbo's Avatar
almost right
n20+FUEL= cylinder pressure=torque(which over time equals horsepower)
remember
nitrous by itself is good for well
nothing but making you sick if you inhale it (automotive grade anyway)
happy racing
jimbo
Old Aug 30, 2002 | 03:59 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Almost right
N20 + Fuel + Air (O2 / Nitrogen / Argon / Carbon Etc..) = Yadda Yadaa
we can do this all day, but I think the fuel part is obvious
Old Aug 30, 2002 | 04:11 PM
jimmbo's Avatar
good catch
you are right
i think some of us take it for a given
you said you were trying to post for those who didn't know
just trying to give insight
but your right
jimbo
Old Sep 1, 2002 | 04:02 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Dynoed at 267hp and 356tq.
Sprayed 361hp and 551tq. at the wheels.
Yea. It gives you a lot of tq.
Old Sep 3, 2002 | 06:57 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Average results for an NX kit is their advertised horsepower, and almost double that in TQ.. My 150 wet shot added 148.1 rwhp and 295 ft-lbs of torque.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
