just testing ignore
Old Sep 18, 2002 | 07:03 PM
superirocz's Avatar
just testing ignore
just testing
Old Sep 18, 2002 | 11:21 PM
superirocz's Avatar
[IMG]002_02[/IMG]
Old Sep 18, 2002 | 11:27 PM
superirocz's Avatar
[IMG]c:documents and settings\administrator\desktop\mypictures\ttiroc\001_01jpg[/IMG]
Old Sep 19, 2002 | 12:38 AM
89ProchargedROC's Avatar
You cant post an image from your computer using the [img] tags.....you have to use the "attatch file" right before the "submit reply" button on the bottom
you can only use the [img] tags when your photo is already on the net somewhere
Old Sep 19, 2002 | 01:07 AM
superirocz's Avatar
I tried that attach file and my pictures are to big, how can i shrink them or make them smaller in size?
Old Sep 19, 2002 | 08:32 AM
email them to me @ koby12@ureach.com
and i'll shrink them down for you
Old Sep 19, 2002 | 11:37 AM
WOW, thats a lot of picture hehehe
i cant keep all those pictures in my inbox otherwise i wont get any emails.......
do me a favor and email them to me again, but not until later tonight sometime...preferable around 10pm your time or so
that way i can download them to my PC really quick and not be bouncing emails back to people
thanks
jim
Old Sep 19, 2002 | 11:41 AM
superirocz's Avatar
Ok 9:00pm eastern standard your in chicago?
Old Sep 19, 2002 | 03:04 PM
ya, i'm central time
so send it to me around 10pm eastern time which is what you should be correct?
that way it gets to me around 9pm and i should be home at that time and be able to download it to my harddrive
Old Sep 19, 2002 | 08:28 PM
The emails are too big and the pictures aren't loading properly......
send me THREE pictures per email
im pretty sure you have 13 pictures so email me 4-5 times with 3 attacthments per email otherwise it wont load properly
Old Sep 19, 2002 | 08:32 PM
i have pictures 02-05 saved already
so only send the ones after that
Old Sep 19, 2002 | 08:41 PM
Old Sep 19, 2002 | 10:28 PM
superirocz's Avatar
I emailed you 3 more pics, thanks 89procharged. Ok i used hedman headers flipped them and cut about a inch off of each and weled the flange on the driver side and a short elbow for the passenger side. Its not symetrical but it should be functional. I relocated the alternator and made the belt tensioner pull the other way like jester did. No AC i ditched it 2 yrs ago thats what the black Z is for I was going to mount the passenger side just like the driver but there was to much interference with the actuator and tensioner. I tac welded everything pretty bad, but my brother should have it all welded up in a few days. I just need to make a passenger down pipe, the one turbo is my friends just borrowed it. Let me knowwhat you think, keep in mind I'am new at this and doing this on a smll budget. I will be running a high dollar front mount IC and wide band computer but for know want to see what the factory ecm and small injecdtors will do. This car runs pretty good already 12.7@111mph with just unported TFW heads and SR intake and a puny cam, The guy @ the dyno said the cam is done buy 5K 321rwhp 390rwtq
Old Sep 19, 2002 | 10:57 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
looks awsome!
You gotta love white cars with blackwheels.
Old Sep 20, 2002 | 12:46 AM
Old Sep 20, 2002 | 07:31 AM
Guido's Avatar
Car: 2000 Trans Am
Superiroc, why dont you take that passenger side and set it up like you have the drivers side with the flange pointing straight up like that. Would surely make it a little neater and keep the heat away from your strut tower over there.
Old Sep 20, 2002 | 10:20 AM
superirocz's Avatar
Thats what i was going to do but the tensioner is in the way and i can't raise the turbo the hood won't shut.
Old Sep 20, 2002 | 12:03 PM
Guido's Avatar
Car: 2000 Trans Am
Get rid of the tensioner. Get rid of that whole bracket. You dont need it. You can match an exact size belt if you HAVE to. You can come up with something to work that doesnt look as unorganzied if you are willing to engineer it a little bit more down the road.
Old Sep 20, 2002 | 02:11 PM
superirocz's Avatar
if i was to cut the top half of the bracket and tensioner off then what? I would be interested in changing it but not sure how. I don't want to switch to v belts. Keep in mind the alternator is located down were the smog pump was.
Old Sep 20, 2002 | 02:12 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Its not really that hard. The alternator can be mounted to the three holes in the head with a little bit of work. If you do it correctly then the alternator won't stick out past the head any, freeing up lots of room. After I did this it seemed like there was a LOT more room on that side.
Old Sep 20, 2002 | 02:15 PM
superirocz's Avatar
ok but how do you make a belt fit without a tensioner? The belt also needs to clear everything.
Old Sep 20, 2002 | 02:24 PM
superirocz's Avatar
does it matter witch way the water pump turns?
Old Sep 20, 2002 | 02:43 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
yes. serpintine WP rotate counterclockwise. The impeller is rotation dependant. If you need to run the WP clockwise just go get a pump from a 87 down F-body.
Old Sep 20, 2002 | 03:16 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
All I see are red X's.
Old Sep 20, 2002 | 05:55 PM
Car: 86 Cutlass
Do a rough fit of how you want to place the alternator, measure the distance around all the accesories, then go to the parts store and make sure they have some belts around the size you need. When I tighten down the alternator it pulls the belt tight. Right now it's not the best setup, but it works. The belt runs from the crank to the power steering pump, around the water pump to the alternator then back to the crank. I believe that GP406Z did something like this as did DM91RS. HTH's.
Old Sep 20, 2002 | 06:15 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
me test too
Old Sep 20, 2002 | 06:49 PM
johnsjj2's Avatar
Car: 1991 Z-28
Okay, I want to see these pictures real bad, but I can't. All I see are red X's except for the pic of the pass side posted by 87 FAKE-IROC-Z. Whats up?
Old Sep 21, 2002 | 03:06 AM
True Power's Avatar
no problems seeing the pics - everything's looking nice
Old Sep 21, 2002 | 10:12 AM
no_car_yet's Avatar
also a test....
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
