NOS won't work!!!!!
Old Oct 10, 2002 | 07:51 PM
speedfreak85's Avatar
NOS won't work!!!!!
Ok, I purged the system, i've got 1000 psi (just filled the tank), and the solenoid is working. What is the problem? I just can't get the nitrous to flow.
Old Oct 10, 2002 | 09:19 PM
Tater13150's Avatar
Do u have a fuel pressure safety switch...if so thats whats keeping the system from working......
Old Oct 10, 2002 | 10:16 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Did you check for kinks in the hose? Does your arming switch work right. Mine had a short in it and I was having trouble until I put in another switch.
Old Oct 11, 2002 | 12:26 PM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
Does the solenoid open? At all even if you complete the circuit with a jumper wire just to test.
Old Oct 12, 2002 | 12:41 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have seen alot of systems fail to work or work inconsistently due to putting all the power through the micro switch, If you didnt use a ralay then you may wish to consider using one AND replacing the microswitch because they get a little burned up inside.
Old Oct 12, 2002 | 01:02 PM
Ok, the solenoid does open, because before i ran it i disconnected it from the carb plate and it sprayed. I went down the track and i flipped the toggle switch and it just bogged down and black smoke was pouring out the exaust. Not sure about the fuel pressure switch. What am I looking for? Thanks for the responses.
Old Oct 14, 2002 | 12:37 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
sounds like you're definitely getting the fuel, but not the NAWS.
Old Oct 14, 2002 | 02:24 AM
mikeage2's Avatar
hmm...maybe the n2o half of the plate is plugged...if your black smoking your getting gas lol i dunno im no expert just a idea
Old Oct 27, 2002 | 08:07 AM
Ryche400's Avatar
If your pressure ever went above 1200 Psi, its probobly the solonoid. Many of the newer NOS brand solonoids have a saftey valve inside that will restrict the flow. I have had that problem before. If you call NOS tech line they will tell you the same thing. You can feel the solonoid clicking, but will not flow.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
