Jester w/in
Old Nov 5, 2002 | 07:23 PM
89_RS_Mike's Avatar
Jester w/in
Jester or anyone else running s-10 V8 swap headers Is there enough room to run 2.5" downpipes under the S-10 headers?
Old Nov 5, 2002 | 09:18 PM
superirocz's Avatar
I think so, I ran 3" down pipes over the valve covers but i thought about doing them under the header it would be very tight with 3"
Old Nov 5, 2002 | 09:23 PM
89_RS_Mike's Avatar
Sounds good, I just wanted to make sure before I bought them but if I can't go under the headers I will just have to go over them
EDIT: What kind of turbos are you running?
Old Nov 5, 2002 | 11:57 PM
82resto's Avatar
Just out of curiosity... does anyone on this board want a turbo header?? I have one sitting around my apartment collecting dust, designed for a SBC.
Jon
Old Nov 6, 2002 | 07:25 AM
Guido's Avatar
Car: 2000 Trans Am
How much are you asking for it 82resto?
Old Nov 6, 2002 | 02:11 PM
82resto's Avatar
I don't know.. what would be a fair price? It's a log style manifold a branch for a crossover pipe built in.
I'm going to try to include a pic...
Since I put a Procharger on my car, I definitely don't need it... thought I admit, another turbo 305 third gen would be quite fun....
Jon
Attached Thumbnails Jester w/in-turbo.jpg
Old Nov 6, 2002 | 03:24 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
that is the exact same unit shown in that Ebay post about the guy selling the whole kit. I figred since rams horns wont work on 3 gens that thatone wouldnt either. this guy Nick124@aol.com is selling a set of manifolds in a banks kit.
Old Nov 6, 2002 | 06:56 PM
83 Crossfire TA's Avatar
Well, it looks like the crossover pipe connection is in the right place for an f-body (if it was straight down like the rams horn ones it would hit the K-member), but that flange (looks like a T3 flange) is probably too far back to clear things on an f-body...
Old Nov 6, 2002 | 07:17 PM
89ProchargedROC's Avatar
i think that is the passenger side manifold crossover.....not the driverside
the turbo would be put right where it needs to be
Old Nov 6, 2002 | 10:45 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I would like to see one like this:
Attached Thumbnails Jester w/in-turboheader.jpg
Old Nov 7, 2002 | 02:46 PM
82resto's Avatar
I don't see how there could be too many problems with getting that to work in an fbody. If it was on the driver side, I feel like it'd hit the crossmember, but definitely not on the passenger side.
Jon
Old Nov 8, 2002 | 01:18 AM
I know it's the passenger side... I'm telling you, that's further back on that side then you'd want. It might work but it will be a pain, too close to the strut tower and will put it right over the main wiring harness, especially if I'm wrong and that's a T04 sized flange (still looks like a T3 to me).
Old Nov 8, 2002 | 10:37 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have one that looks VERY similar to that one. The flange has the same bolt pattern as a T4 but the opening is slightly different. It is nothing that a little porting won't fix though.
With having the turbo that far forward, won't the intake hit the A/C compressor?
Old Nov 8, 2002 | 03:37 PM
not on an '87 and earlier car. The Alternator is on that side and it's much smaller. For that matter, on the '87's the alternator is mounted a little further in (I think just a shorter belt) and is almost entirely in front of the engine.
Jester
Carburetors
Dec 13, 2001 09:08 PM
ede
Carburetors
Oct 20, 2001 02:39 PM
jaretz28
Apr 30, 2001 12:42 PM
SeanSullivan
Carburetors
Mar 19, 2001 12:49 PM
Jester
Carburetors
Sep 12, 2000 01:24 PM
