ProCharged w/ knock !!!! Help.
Old Jan 25, 2003 | 08:32 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I am running a 1991 TA 305 TPI with a ProCharger (10 # boost). I am getting knock and timing retard with just a flash of boost.
I am looking into either a boost timing control module or an alky/water kit.
Please let me know what the consensus is on these items.
I currently have a Jacob's Pro Street set up so I would prefer to find something that would allow me to keep it. Brand new.
Thanks.
Old Jan 25, 2003 | 09:34 PM
StocRoc's Avatar
What's your base timing set at?? Are you running an aftermarket chip? What kind of plugs are you running, and what is the gap?
Old Jan 25, 2003 | 09:41 PM
mypontiac's Avatar
Car: 1991 Conv. TA
I am not sure what the base timing is at. Have to check data at idle. I am working with a prom programmer. He is trying to get the knock down, but he said there is only so much he can do in boost with the speed density set up.
The plug gap is at 35 as recommended by Jacob's.
I have read many threads on this today and it looks like most others running boost have had this problem.
Many have solved it successfully with alky/water injection.
Looks like list member Newtowner is selling SMC kits for less than Steve directly. So I am probably going that route.
Thanks.
Old Jan 25, 2003 | 11:05 PM
StocRoc's Avatar
sounds good, how much is the kit.
Old Jan 25, 2003 | 11:08 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Looks like $350. Even used they are going for over $300.
All the post I read say the kit is well done and worth the $$$.
Here is a link for you:
http://www.smcenterprises.com/
Old Jan 26, 2003 | 12:48 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm running the MSD 6BTM. I highly recommend it. The MSD 6BTM allows the driver to retard the ignition timing based on the amount of boost being produced by the supercharger. The timing is adjusted from a dash mounted **** and can be retarded 1 - 3° per pound of boost with a maximum of 15°. There is also a built-in adjustable rev control to protect the engine from over-rev damage. PN 6462
Old Jan 26, 2003 | 08:40 AM
StocRoc's Avatar
mypontica- that looks like a really nice setup, and it is very well priced. That is something I may have to look into. Keep us all posted please.
Ryan
Old Jun 19, 2003 | 09:44 PM
mypontiac's Avatar
Car: 1991 Conv. TA
I talked to Steve today about his alky/water kits and if they are applicable to supercharged cars.
Reason being that I am going to 15# boost on a stock bottom end and need the added insurance!!!
He said that his current kits are made for Turbo Buicks and the spray comes on full at a set boost. Usually 12#.
He said that he is a month away from putting out a progressive kit that will be for supercharged engines. The pump speed will increase with boost giving more spray as boost increases. Thereby giving spray for the entire boost cycle.
I will be looking into this kit.
He seems to get great response from those with his product. And the price is resonable.
Will keep you posted.
Recaro trans am
Jul 23, 2013 07:58 AM
zapo
Feb 26, 2005 10:38 AM
Ions91Z28
Feb 28, 2003 10:30 AM
1LE OWNER
Sep 15, 2002 06:54 PM
iroc90
Feb 27, 2002 02:15 PM
