Mounted twins.....pics w/in
Old Mar 10, 2003 | 12:33 PM
JC93Z's Avatar
Old Mar 10, 2003 | 02:08 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
the engine looks so...small...
after seeing so many v8 engines, the v6 looks tiny
looks lot easier to work on, however
Old Mar 10, 2003 | 03:54 PM
Guido's Avatar
Car: 2000 Trans Am
It was a breeze fitting them in there compared to my own project. Youd think being a 4th gen would limit the options, but slicing two cylinders off the front made the difference. All the time was in finish welding the headers together.
Old Mar 10, 2003 | 10:00 PM
MdFormula350's Avatar
:hail: awesome!
Old Mar 10, 2003 | 10:18 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Looking good. Where are you running the oil return to? The headers look too low to run to the original spot so I'm ASSuming you'll run to the oil pan. I'd be interested in some pics of however you end up doing the oil return.
Old Mar 11, 2003 | 07:06 AM
JC93Z's Avatar
Greasemonkey: You are correct, I will run them to the oil pan with braided line.
Old Mar 13, 2003 | 10:28 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
thats a lot of weight to have hanging on those headers. i would fab up a two direction brace that bolts to the motor or you will blow header gaskets a lot.
thanks
anthony
Old Mar 14, 2003 | 07:05 AM
Guido's Avatar
Car: 2000 Trans Am
We plan on supporting them azzkicker. We think the stock heat shield bracket will make for a good spot to support the turbos from.
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
