I need a bottom end to hold a 250 shot . . . . . . . . . . . .
Old Mar 24, 2003 | 04:13 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm looking for a good nitrous piston rod and ring set up. I just found out that I have no compression in my #1 cylinder so I'm going to tear the motor down and forge the bottom end. I plan on spraying a 250 direct port. Either a 2 stage or a progressive controller. I have the standard 20920 kit from NX now w/ the GenX II. Will I need to upgrade the solenoids for the 250 shot? Also How can I tell if my crankshaft is forged? I've heard different things about the ZZ4 motors. Thanks inn advance.
Old Mar 25, 2003 | 03:33 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
ttt
Old Mar 26, 2003 | 02:25 AM
onebadwagon's Avatar
good forged crank good h beams good forged pistons
i run
(lol) stock crank
eagle hbeams
ross pistons.
have yet to see how itll do, but it will be putting down 400ishrw on motor, and then a 250 shot.
Old Mar 27, 2003 | 11:27 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Where did you get your eagle h-beams from? I didn't see them in summit. Do you remember how much they were?
I was also planning on studding the main caps. What made you choose ross over JE? Just curious, I was looking at the prices and they seemed to be about the same.
One more thing, Does Ross or JE make any 4.000" bore slugs? All I see listed are 0.030" and up.
Old Mar 27, 2003 | 01:22 PM
gtabadboy's Avatar
My bottom end withstands 300...I have yet to shoot this much. Basically you need forged pistons, H-Beam rods for added safety over I beams and a forged or nitrided crank. See my sig. Also search online for places to purchase good eagle components just type rotating assemblies.
Old Mar 28, 2003 | 07:05 PM
je or ross will make you any piston you want, just ask them.
i bought my whole shortblock for 1400 if i remember right.
adam
Old Mar 30, 2003 | 05:23 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
What do you set your ring gap at? I was told that speedpro hellfire rings are good.
I was also told that when I order the pistons that I should tell them that it will be a nitrous motor and to make sure the ringlands are farther down on the piston.
Sorry for all the questions, but I only want to do this once.
Old Mar 31, 2003 | 03:19 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
lol i have forged bottom end and im wondering if this 200 shot i put on will actually work lol
Old Apr 1, 2003 | 11:33 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
What kind of wrist pins should I get? Floating or the kind w/ the C-clips. What are the plus and minuses of both?
Old Apr 4, 2003 | 08:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I got my H-beam rods for $262 from this guy http://cgi.ebay.com/ebaymotors/ws/eB...407909953&rd=1 he is a major seller on ebay and sells them all the time.
Attached Thumbnails I need a bottom end to hold a 250 shot . . . . . . . . . . . .-i-1.jpg
Old Apr 6, 2003 | 06:36 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Ok, how does this sound
ross nitrous pistons
manley forged H-beam rods
studded 4-bolt main caps
And AFR 195's for a little umph on the top end.
Think it'll go 10.50's ?
Old Apr 6, 2003 | 08:44 PM
sounds alot like my shortblock, but ive got hbeams and a two bolt, i should be an easy 11 second motor car, with 3.55 gear,
so yeah, with good heads, and a 250 shot, you might go 10.50s
im also running heavily ported victor jr's. probably 220cc intake runners.
adam
theshackle
Mar 5, 2017 06:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 21, 2015 07:20 PM
