What is the best hooking street tire out there?
Old Apr 2, 2003 | 08:30 AM
WickedTwinTurbo's Avatar
My beast is ready to roll, I need to know what is the stickiest tires out there? I have the factory 16"GTA rims on the car, what size and what brand? Quick time pro's? ET street?
T.I.A
Prasad
Old Apr 2, 2003 | 11:07 AM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
For the money, I'd really look into some ET Streets. My friends 85 went 9.97 @ 136 with these tires. I forget the exact spec's on em, but they hook good.
Old Apr 2, 2003 | 11:09 AM
89ProchargedROC's Avatar
The ET's will last longer on the street because the rubber compound is harder than the DOT Hoosiers. Because of the harder rubber of the ETs they will also be a bit less consistent
I would go with the ET's for your street tire on the 16" rim. Use the 26 x 11.5 x 16 tire. That is what im going to be using. Not bad for all around driving just ABSOLUTELY NO RAIN. with good pressure in the tires i know people who have gotten 7,000 miles outta a set
Old Apr 2, 2003 | 12:52 PM
BOTLFED's Avatar
Hey Prasad, how are things?
I'll have to side with these guys on the ET Streets.. They the best I've seen.. I run 26x11.5x15's and they hooked extrememly well with my 150 shot.. Now that I have the twins tho, it's a different story, but I bet it has to do with the cold weather and light salt residue on the street..
Also, my friend runs 10.2's on them in his 2600 lb datsun..
ET Streets all the way!
Cheers,
Old Apr 2, 2003 | 02:05 PM
Thanks for the quick reply guys, what about tire pressure and setup info. Hey Drew whats up? are you done with tuning your beast.
Old Apr 2, 2003 | 02:09 PM
BOTLFED's Avatar
LOL, done tuning? I don't think I'll ever be done...
I run about 20 psi on the street with em and they don't even handle that bad.. With 16's, it might actually handle ok..
Cheers,
Old Apr 2, 2003 | 08:09 PM
Mark W. Winning's Avatar
I ran faster on the Hoosier Quick Time pros than I did on ET drag slicks. That says a lot for the Hoosier. From what I have seen the ET Streets are just as good.
Mark
Old Apr 4, 2003 | 09:00 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I think the best hooking street tire for its size that I ever ran were those M&H racemasters in the G60-15 (like 8.5"), I basically am a M/T ET street guy now but I plan on experimenting someday to see how they pan out. they use some different sizing now (like et streets) but I think if they hook now as good as they did back then I might switch.
Old Apr 4, 2003 | 09:02 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here is a cool article http://www.nhra.com/dragster/1999/is...echnology.html
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Feb 13, 2016 10:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
g.l.mos
Aug 22, 2015 12:02 AM
