How much PSI for O-ringing block
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
for a non intercooled app weiand says no more than an effective compression ratio of 12.5:1
on most 9:1 compression 350's this is about 6 PSI of boost.
But technically, you shouldnt need to O-ring so long as cylinder BMEP's are kept below 300 PSI (such as very high boost / N20 at a very low RPM) and as long as detonation is kept under control you can run as much boost as you want without an O-ring.
its the super high cylinder pressure, and detonation that blow headgaskets.
if you Oring your motor, then its basically proof against #1 the super high cylinder pressures, but NOT detonation. if your block is Oringed then instead of blowing a headgasket you will put a hole somwhere in your bottom end. not good.
Car: 1992 B4C 1LE
head gaskets are a good safety seal, I will be using felpro loc-wire head gaskets as my "fuse"
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
My block/heads aren't o-ringed and I haven't had any problems with 20+psi of boost. As was already said, just avoid detonation and the resulting spikes in cylinder rpessure and you should be fine.
Car: 1992 B4C 1LE
holy mangled gaskets batman. Are those JE/SRP pistons? did they fare well?
Transmission: 4l80e
Axle/Gears: 3.512
I am also using JE blower pistons, 9.5:1 in a 6" rod 383 motor. Its not built yet, but that picture gives me comforte.
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Originally posted by 87transam5.7tpi
in that picture is your block cracked at the stud? what kinda gaskets were u using?
Car: 1992 B4C 1LE
they look just like mine thank *** they survive :-)
RyanJB
Sep 14, 2015 03:39 PM
